It is currently Tue Mar 03, 2015 5:25 am
 Post subject: Easy Media Creator 7 Review
PostPosted: Mon Aug 30, 2004 6:58 am
In your review of Roxio's Easy Media Creator 7 (forgot witch issue),
you guys said it had a "fit-to-disk" feature that could burn 1 gb to a
regular cd. I can't find \ use this feature. Plz tell me how!
 Post subject: Re: Easy Media Creator 7 Review
PostPosted: Mon Aug 30, 2004 7:10 am
that's a feature for the Plextor burner, and Plextor software.
PostPosted: Mon Aug 30, 2004 12:36 pm
I'd rather be modding!
see above.
But if you mean will it prompt for an additional blank, yes it will. So, if you are trying to burn a file that is two long it will put it on multiple CD's
Manta
