It is currently Wed Jan 28, 2015 5:30 pm
 Post subject: logitech keyboard and my "Backspace" key sticks
PostPosted: Sun Aug 29, 2004 9:03 pm
Hey guys, I just got this Logitech Wireless keybaord and from day 1 the Backspace Key sticks. Is there something I can do to stop this key from sticking? Its pretty annoying as almost everytime I press backspace the key sticks down and I have to mash it to get it to come back up.
Any help would be great.
PostPosted: Sun Aug 29, 2004 9:12 pm
Team Member*
Team Member*
Well i guess it depends on how adventurous you are. You can either open the keyboard up to see if there is an issue with the key or you might be able, and this is a big might, to pop the key off and check the area underneth the key. Was this purcahsed new? If so then return it it before you do any of that!!
If you got it from a good place they should be able help you out.
PostPosted: Mon Aug 30, 2004 12:31 am
if the product is new, i would definitely returned it.
PostPosted: Mon Aug 30, 2004 12:58 am
hmm well if its new enought i would definitly return it.
Users browsing this forum: FascistNation and 7 guests
