It is currently Fri Jan 30, 2015 4:12 pm
 Post subject: Full 5.1 Support on S/PDIF with DVDs
PostPosted: Sun Aug 29, 2004 7:30 am
I'm running PowerDVD 5 with my A7N8X-DX Mobo (dats nForce 2, with SoundStorm onboard). I have the Klipsch GMX D-5.1 speakers, which only use my digital out.
when i play DVDs (any DVD, makes no difference, even they have explicit Dolby Digital 5.1), i never get any sound out of my center or rear channels. I know that these channels work, because i can play music out of them.
I have the latest nvidia drivers, which are driving me nuts because the NVMixer doesnt present as much control for your outputs as the nvidia control panel did.
Any ideas how to get my extra channels working?
PS I'm not some dumb n00b... i didnt do anything dumb like not enabling 5.1 the Dolby Digital thing on my speakers... please do reply to tell me to plug in the speakers...
thanx for the help!
PostPosted: Sun Aug 29, 2004 12:43 pm
Have you had a look here?
Am using PowerDVD v5.0 with no problems.
PostPosted: Sun Aug 29, 2004 4:59 pm
yes i've set it to use the SPDIF and no change... i've even tried to use the 5.1 settings and have the encoders do the digital thing... but no change. if i set it to use 6.1 Dolby Digital, the sound goes away period.. no sound
but thanx for the suggestion.... anything else?
