It is currently Mon Jan 26, 2015 8:06 pm
 Post subject: TV Tuner + Audigy2 zs problems
PostPosted: Sat Aug 28, 2004 11:13 pm
ok, I've tried, I can't figure it out.
I installed my Audigy2 zs, and the thing has been pretty decent for a while. The problem this time is now my TV Tuner (a leadtek winfast 2000xp deluxe) outputs amazingly poor sound quality and beyond that, I can't even control said sound through the interface of the program. (ie raising the volume bar in the program has no effect on the volume of the TV that I watch, I have to change the system volume).
I checked in the preferences and the only information readily available about the sound format is that it is indeed using the Audigy2 zs. The updated drivers/app didn't do anything at all.
Everything else sounds pretty good, I'm liking actually using 5.1 sound.
IF anyone has any ideas, please tell me.
PostPosted: Sat Aug 28, 2004 11:57 pm
Maybee try going thru your onboard sound to verify that its not the Tuner that is screwed up?
PostPosted: Sun Aug 29, 2004 1:13 am
Eh? That's the point of the post. I installed my *new* audigy2 zs, hooked the tuner card up to the audigy the exact same way it was hooked up to the onboard sound, and now it's as I said before.
PostPosted: Sun Aug 29, 2004 12:01 pm
ah, my bad i understood that you installed it the other way around. hmmmm
