It is currently Thu Jan 29, 2015 1:45 am
 Post subject: PLEASE HELP...NEED TO LOCATE SYSTEM CLOCK
PostPosted: Tue Aug 24, 2004 8:25 pm
I set the mater password on my friend's HP Pavillion N5350 notebook and the power went out in the process. Now, it asks for the password but won't recognize anything I type. I know a way to reset that password is to remove the system battery for 10 second.
PROBLEM: I OPEN THAT LAPTOP AS MUCH AS I COULD AND SEE NO SYSTEM BATTERY. DOES ANYONE KNOW WHERE IT IS LOCATED?????
PLEASE HELP. HER EXAM IS DUE IN 2 DAYS AWAY AND ALL THE WORK IS ON THAT THING.
PostPosted: Tue Aug 24, 2004 8:36 pm
I hope this helps.....i almost lost schoolwork at a bad time too once :) Just register at those forums and ask someone there or possibly somone else here knows how to help you.
http://forums1.itrc.hp.com/service/foru ... 3+28353475
PostPosted: Wed Aug 25, 2004 3:59 am
To my knowledge, the only system battery in a laptop is just that, the battery, you know that big brick ;) Yank it, turn on the laptop and keep it running till any stored juice is expended.
PostPosted: Wed Aug 25, 2004 7:35 am
i dissect that thing to pieces and still no battery. i called the not-so-friendly-because-product-is-longer-under-warranty customer support and they suggest i send it in along with 250 check for the work. hp.com is probably the worst help site out there.
another friend of mine got almost the same model as this one, he'll look up stuffs and help me.
NOTE TO SELF: NEVER BUY A HP LAPTOP OR EVEN A HP COMP. i never used that tech support that came with the thing, so i figure they should help me at least 20 times over the phone no matter long old the thing is.
PostPosted: Wed Aug 25, 2004 10:38 am
If your friend really needs to use the comp that bad, why not just pull out the harddrive and copy the files. Then fix the problem.
PostPosted: Wed Aug 25, 2004 11:38 am
it's a laptop hard-drive, I wouldn't know how to pull the data.
Anyway, I think I just killed the laptop. I found the battery but it is super glued to the metal wires, which are, in turn, stitched to the motherboard. I broke one of the 2 wires from just adjusting the battery.
NOTE TO SELF: DON"T BUY HP LAPTOP BECAUSE IT IS NOT USER-FRIENDLY. IT FALLS UNDER THROW-AWAY-AFTER-2-YEARS COMPUTERS CATEGORY.
I do appreciate the help from everyone. Gracias.
PostPosted: Wed Aug 25, 2004 11:59 am
Well, just swap the harddrive to another notebook.
PostPosted: Wed Aug 25, 2004 3:33 pm
King of All Voodoo2 Cards
All laptops have their own dedicated clock batteries, otherwise everytime someone changed their battery, they'd lose their Date/Time, CMOS settings.
PostPosted: Wed Aug 25, 2004 3:45 pm
http://www.uktsupport.co.uk/reference/biosp.htm may help anyone else with this problem. Most bios manufacturers put in backdoor passwords that will work even if you have set a new one.
PostPosted: Wed Aug 25, 2004 6:30 pm
I wouldn't call HP's junk or not user-friendly based on human error either. The poor thing didn't change the password or break the battery connection by itself. But I do understand that tech support blows. I think they have too much Compaq in their blood since the merger.
A manual would have been nice as well. I would have hoped for a jumper, as every HP desktop I've dug in had one, but not sure on laptops.
But, $250 doesn't sound bad now that the laptop is entirely inoperable now;) Now how to solder?
PostPosted: Wed Aug 25, 2004 6:38 pm
I seem to recall HP laptops had that...although not a jumper, but rather a reset switch that you had to push with something like a paperclip or a mechanical pencil.
I want to say if it'll be anywhere, it'll be on the backside somewhere close to the battery (the one that runs the laptop) if not underneath when you take that out.
PostPosted: Wed Aug 25, 2004 6:48 pm
My little Dell had a hole through the bottom. Think it simply says "reset". I'll have to check it out. Not that every laptop has it, but manuals sometimes help ;)
PostPosted: Wed Aug 25, 2004 7:35 pm
Dunno if it's too late but...
http://www.pricegrabber.com/search_gen. ... e=googlecp
PostPosted: Tue Aug 31, 2004 7:54 am
The thing I hate about this laptop is that I can't find the battery any where. The part that I thought was the battery may not be the battery, but then if it is the battery I don't know where "the battery" is located. I opened it up 85% with extreme care. There must have been hundreds of screws which I still question who approved this hardware setup.
Is there a way to stitch a piece of metal (very tiny) back together. I was thinking about taping a small paper clip so that the current will flow from each broken end to the other. There is a power reset switch, but it won't reset the password. I have Linux rescue CD that will reset Wins admin password (Windows is a joke on security) but this system password is tough.
Any suggestion is appreciate. And what took you guys so long to reply?
PostPosted: Tue Aug 31, 2004 7:58 am
hey flytrap,
if only this hp has that easy of a setup. life would be much better.
PostPosted: Fri Sep 03, 2004 6:18 pm
Are you fucking kidding me? Do you think we get paid for this?
