It is currently Mon Apr 27, 2015 3:32 pm
Post new topic Reply to topic  [ 31 posts ]  Go to page 1, 2  Next
 Post subject: Help ! Motherboard, etc. will not start at all !!!!
PostPosted: Tue Aug 24, 2004 12:21 pm
first time upgrading motherboard, RAM and processor: hooked everything up, and nothing happens. What could be wrong ?
PostPosted: Tue Aug 24, 2004 12:22 pm
You're grounding somewhere??
That's my best guess based on the info you provided.
PostPosted: Tue Aug 24, 2004 12:24 pm
nothing powers up at all....it's totally dead, nothing !
PostPosted: Tue Aug 24, 2004 12:29 pm
forgot the power switch connector?
PostPosted: Tue Aug 24, 2004 12:31 pm
i don't think so...maybe I hooked it up wrong
PostPosted: Tue Aug 24, 2004 12:38 pm
Yea...and that's exactly what grounding would do.
Power connector isn't a bad idea either.
PostPosted: Tue Aug 24, 2004 12:41 pm
when i install the mobo onto the standoffs, the mobo directly touches the metal standoffs, right ?
PostPosted: Tue Aug 24, 2004 1:26 pm
Team Member Top 100
Team Member Top 100
particulars on the mobo, proc and mem, please.....
Ken_Campbell
Fold Until A Cure
PostPosted: Tue Aug 24, 2004 1:43 pm
Ken_Campbell
Fold Until A Cure
FIC K8-800T motherboard for 64 bit, AMD Athlon 64 2800 processor, PNY 512 MB PC3200 DDR400.
PostPosted: Tue Aug 24, 2004 2:11 pm
newbiesteve wrote:
Ken_Campbell
Fold Until A Cure
ok I tried powering the mobo with only the fans attached and power switch attached. Nothing at all. I'm starting to think that 1) the mobo was bad or 2) I fried it accidentally. Oh well.
PostPosted: Tue Aug 24, 2004 3:05 pm
Team Member Top 100
Team Member Top 100
Did you get a mounting bracket for the heatsink? Some of the early on boards didnt have one and it caused shorts.
Ken
Fold Until A Cure
PostPosted: Tue Aug 24, 2004 3:20 pm
Contributing Writer
Contributing Writer
Try reinstalling your mobo, making sure the screws are tight and triple checking your standoffs. Physically take your motherboard out and reinstall, don't just double check it by eye. You can also try booting it up outside of your case.
In addition, reseat your CPU and heatsink.
Lastly, triple check your headers.
PostPosted: Tue Aug 24, 2004 4:30 pm
One woukld hope.
BUt that's not the only place this could happen.
I'd at least try to power it on..outside of the case, while it's resting on something non-conductive.
PostPosted: Tue Aug 24, 2004 5:03 pm
Ken
Fold Until A Cure
I think so. This is a "brand new" board supposedly. I mounted the CPU correctly, I believe. I then applied Arctic Silver 5 thermal compound on top of the processor, and then mounted the heatsink and fan on top of it, making sure the brackets were secured.
PostPosted: Tue Aug 24, 2004 5:05 pm
furball146 wrote:
One woukld hope.
I did try to do that, great suggestion. Neither the CPU fan or the case fan would move. I am worried that I have fried the mobo by accident.
PostPosted: Tue Aug 24, 2004 5:06 pm
dumb question: what are headers ?
PostPosted: Tue Aug 24, 2004 5:37 pm
Contributing Writer
Contributing Writer
I was referring to where you plug your case's HDD LED, Power Switch, Reset Switch, and Speaker to the motherboard. If you have the power switch plugged in incorrectly, it will not power on when you hit the button.
PostPosted: Tue Aug 24, 2004 5:43 pm
OK, I am real unclear as to exactly how to do that. The schematic for the mobo was not real clear. The four switches are all on a very small panel.
PostPosted: Tue Aug 24, 2004 5:46 pm
http://www.fic.com.tw/product/motherboa ... -800t.aspx
PostPosted: Tue Aug 24, 2004 6:13 pm
Contributing Writer
Contributing Writer
Doesn't look like FIC has an online manual for that mobo :?
In any event, remove everything else and concentrate on getting the Power switch plugged into the correct spot. If it's not, you can't turn your system on.
