It is currently Mon Apr 27, 2015 11:43 pm
 Post subject: Highjackthis program
PostPosted: Thu Aug 19, 2004 9:48 am
Does anyone use highjackthis? I nneed someone to look at the readout of stuff from my computer and tell what I can delete. Is the a place where I can get that help.
PostPosted: Thu Aug 19, 2004 9:52 am
Post it here, and I'm sure we can figure out what you don't need. :)
PostPosted: Thu Aug 19, 2004 10:34 am
Easiest thing to do is to stick the name of the unrecognized file or service into google. The first 5 results will invariably tell you what you need to know.
You'll soon get a feel for what should and should not be running on your PC.
<=T=
PostPosted: Thu Aug 19, 2004 10:44 am
I use highjackthis along with bazooka. first I run bazooka and if it detect anything I look at the reg keys that bazooka points out and then use highjackthis to easily delete those keys. This is easier than going into the regedit and look for those keys. Great programs by the way.
PostPosted: Thu Aug 19, 2004 2:19 pm
Hijack this is the shiieeeaattt, I clear up so many computer problems spyware and other issues with it. at first it will look like something complicated but it's not, you can usually check 80% of the shit that comes up.
