It is currently Thu Mar 05, 2015 12:34 am
 Post subject: IO.sys prob
PostPosted: Thu Aug 19, 2004 8:15 am
I need to delete it in dos
only way I can see is is
dir/w/a
Then I try
Del *.sys
and
del io.sys
still nothing how do I make it a non attributed file or just flat out delete it?
PostPosted: Thu Aug 19, 2004 9:45 am
cd \
attrib -s -h -r io.sys
delete io.sys
PostPosted: Thu Aug 19, 2004 9:52 am
Ummm .. why are you deleting that file?? :shock:
PostPosted: Thu Aug 19, 2004 2:21 pm
I'm trying to reinstall Windows, but I keep getting the error saying I need to use the upgrade CD. It's a dumb error and I'm trying to get around it by del some things so it doesn't see the os. Guess it doesn't work
PostPosted: Thu Aug 19, 2004 2:56 pm
How are you trying to run that? Usually you just want to run it out of a dos prompt off of a bootdisk.
PostPosted: Fri Aug 20, 2004 4:13 am
yeah I'm running it off a Win98 SE boot disk, then loading setup. Just says there is already a os installed and I need the upgrade cd to install windows. isn't that funky?
PostPosted: Fri Aug 20, 2004 6:38 am
You won't be able to reinstall the OS by trying to nuke the individual files that comprise it ... you'll just b0rk your PC.
Back up your software and data, and reinstall completely. Consider investing in a better OS, such as WinXP, so you don't have this problem in the future. :)
