It is currently Wed Apr 01, 2015 10:50 pm
 Post subject: Squealing pc
PostPosted: Thu Aug 19, 2004 5:22 am
My pc woke me up this morning with a loud squealing noise coming from the speakers,no video and it will not boot.
Epox 8rda+, xp2600mobile at 2400mhz,audigy2,nvidia 5900 video, 2x512 pny pc 2700 ram and XP pro.
I think something died but do any of you have any ideas? Thanks. :(
PostPosted: Thu Aug 19, 2004 5:54 am
7yrs+11,000 Posts
7yrs+11,000 Posts
there moght of been another audio device on at the time, and it may of been feedback.
 Post subject: Re: Squealing pc
PostPosted: Thu Aug 19, 2004 6:30 am
I'd rather be modding!
Nothing was sitting on the keyboard? Like a Cat maybe?
Anyway - since it won't boot - does it post? anything? (really do need to know this)
Could it have gotten a surge? Was there a storm?
Anyways, we need just a tad more info - like does it POST or does it beep on startup.
Manta
PS, on the slim chance that Gamerfreak is right, pull the sound card and see if it boots.
PostPosted: Thu Aug 19, 2004 6:37 am
7yrs+11,000 Posts
7yrs+11,000 Posts
I hate it when my kitties step on the keybord, one time i was just abiut to type in a registration passwors and he jumped on it and hit enter too, it didnt ask to conferm password.
Not to get off topic but, post more info
 Post subject: reply
PostPosted: Thu Aug 19, 2004 6:47 am
There was nothing on the keyboard. It will not post or boot. The digital readout on the board starts and stays at FF . It used to cycle through a series of alphanumeric characters before reading FF.
Thanks for your replies and for my backup pc. I almost sold it.
 Post subject: Re: reply
PostPosted: Thu Aug 19, 2004 6:58 am
FF = 256 (actually, 255)
Don't know what that means. - possibly memory. DO you have the MB manual?
Anyways, since it won't post I think you are looking at:
Bad PSU
Bad memory module
Bad MB
or
Bad CPU
Do this I think:
Can you check another PSU? That would eliminate that right off.
Pull all unneed cards out and unhooking all drives and see if you get a post.
Then check the RAM by putting in just one module at a time (I am brain dead right now - but I think you can do that with your stuff - please check). If not switch the order of the modules and try to get a post.
Check the CPU HSF and make sure it is seated with good thermal compound (not dried out).
I am out of ideas after that - but I am kinda distracted so maybe more/better ones will come.
Manta
PostPosted: Thu Aug 19, 2004 7:24 am
try opening your computer case and strippin the taking out the parts that are not needed for a computer to post. take out all your optical drives and even hdds. you only need the power supply, mobo, cpu, ram, and video to make a computer post. do this so you will narrow your problem down to one of these devices. could ge a dead power supply, test this first like someone said so you can rule this out.
PostPosted: Thu Aug 19, 2004 11:19 am
Swapped everything but powersupply and mobo. I noticed swollen caps on closer inspection. DANG!
PostPosted: Thu Aug 19, 2004 12:58 pm
Oh that sux man - -sorry :(
I thought that stuff was worked out of the market already.
Manta
PostPosted: Thu Aug 19, 2004 1:04 pm
hmm, i've seen on Epox bashing on this board, chalk this up to another i guess.
PostPosted: Fri Aug 20, 2004 4:46 am
About two years for the old epox and now it is gone.
