It is currently Thu Mar 26, 2015 11:33 pm
 Post subject: ICS for xp question
PostPosted: Wed Aug 18, 2004 6:45 pm
Hi
i have two computer that are networked together via a hub.. my main computer is p4 2.8 with 1 gb of memory and is running win xp pro. i also have another computer that has win 2k server installed. i use the win 2k for studying (trying to get my mcse). Win 2k as AD installed dns, dhcp etc...etc.... win xp has a 56k connection to the internet...win 2k doesn't even have a modem installed....i am trying to share the dial up internet connection from win xp to win 2k server....but from what i can understand i can not use ICS from win xp to win 2k....like i said xp has to be the one with the internet connection.....i could install a modem in the 2k computer but now i must know how to do it...it's a lil embarrassing too, because i am studying for this stuff and i can't figure it out... :oops:
anyway thanx
PostPosted: Wed Aug 18, 2004 8:39 pm
Sailorman
Sailorman
Make sure ICS is only enabled on the host computer not the W2K machine.
PostPosted: Thu Aug 19, 2004 12:57 pm
any other suggestions???
PostPosted: Thu Aug 19, 2004 5:04 pm
Sailorman
Sailorman
Run the network setup wizard on the XP machine. It will offer to make a setup disk for another computer when it finishes. Make the disk and use it on the Win2000 machine. It should make all the settings required to use ICS.
PostPosted: Thu Aug 19, 2004 7:08 pm
i did that and i am told that ics does not work on win 2k..if you go to help within windows you will read the same thing...or at least that's my understanding.....it's a lil late right now but tomorrow i'll try to uninstall dhcp and i'll try withou that..
PostPosted: Thu Aug 19, 2004 7:34 pm
you need to go into the properties of the network adapter of your win2k machine. in the tcp/ip settings, make sure that the default gateway is the ip address of your xp machine, and that both machines have different ip addresses, but the same subnet mask.
