It is currently Fri Apr 24, 2015 10:59 pm
 Post subject: CPU fan stops intermitently
PostPosted: Wed Aug 18, 2004 6:25 pm
My CPU fan was stopping on occasion, a little clean air and it would run. After a while I figured I'd better just buy a new one. After only a couple of weeks this one does the same thing. The computer runs just fine otherwise, with the excetion of it sometimes not wanting to come out of sleep mode,
I have:
AMD Duron 900
256 MB Ram
Asus A7V-E Mobo
Any help would be great.
JR
PostPosted: Wed Aug 18, 2004 6:27 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
sounds like your power supply, check thats you cords are snug and
specs of psu please???
PostPosted: Wed Aug 18, 2004 7:00 pm
I agree with gamerfreak, this sounds like a power issue.
Specs on your power?
PostPosted: Wed Aug 18, 2004 7:20 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
ohh ohh i was right for once
 Post subject: Re: CPU fan stops intermitently
PostPosted: Wed Aug 18, 2004 8:19 pm
King of All Voodoo2 Cards
Check to see if there's a BIOs upgrade for your motherboard. I had a problem with one of my board where the CPU fan wouldn't start back up after coming out of suspend or hibernation. The company that made my board came out with a BIOs update later that fixed the problem.
