It is currently Sat Apr 25, 2015 6:05 pm
 Post subject: Windows Reinstall Error
PostPosted: Wed Aug 18, 2004 8:14 am
I'm trying to install Windows ME on a system but I get the error durring setup of windows ME OEM
Your computer already has an operating system installed, which cannot be upgraded by this version of setup. You need to obtain the Windows ME Upgrade
SU0168
Is there a way around this?
PostPosted: Wed Aug 18, 2004 8:19 am
Other than wiping the drive first, I don't think you're going to get around it unless you can scam an upgrade edition off of someone.
I always recommend putting the OS on it's own partition, and user files on another. That way OS upgrades/reinstalls don't put your data at risk.
<=T=
PostPosted: Wed Aug 18, 2004 8:31 am
Usually this comes from a couple of things...either the CD is not reading the disk right or you have a bad stick of ram.
PostPosted: Wed Aug 18, 2004 10:17 am
or I could rename win.com
