It is currently Fri Jan 30, 2015 8:50 am
 Post subject: Red/black stuff on my screen?
PostPosted: Tue Jul 29, 2014 5:21 pm
I tried to get some good pictures of the screen, but it doesn't come out that well. In any case, these are red and black pixels on my screen. Is there any way I can fix these?
 Post subject: Re: Red/black stuff on my screen?
PostPosted: Thu Jul 31, 2014 11:44 pm
No, the panel is going dead. Since I assume it's past warranty, it's time to replace it (or live with it).
I guess if we want to doubly check to make sure it is the panel and not the GPU, plug it into another computer or video card.
PostPosted: Fri Aug 01, 2014 3:46 pm
If you are using the DVI port, try using the VGA port on the monitor. The DVI side is dieing but that does not mean the VGA is also.
I already proved this out on a friends monitor and it works.
