It is currently Mon Jan 26, 2015 8:08 pm
 Post subject: CPU fan running @ below 400 rpm constanly
PostPosted: Tue Jul 15, 2014 5:55 pm
CPU Cooler: http://www.newegg.com/Product/Product.a ... 6835118046
Mobo: P8Z68 Deluxe
I've tried everything to bump up the fan speed from bios setting and everything. But it will not go over 600 rpm. But it mostly stays at below 400 rpm. All I can think of doing next is disable TPU/ EPU. I've seen the fan go up 1300 on bios once.
 Post subject: Re: CPU fan running @ below 400 rpm constanly
PostPosted: Tue Jul 15, 2014 6:45 pm
What are your temps? What happens when you remove the resistor wiring?
PostPosted: Tue Jul 15, 2014 7:12 pm
I'm getting 90+ running prime95 just for a few minutes. What wires are you talking about?
PostPosted: Tue Jul 15, 2014 7:18 pm
There is a small extension harness maybe about 3 or 4 inches with a male and female plug with a resistor on the yellow wire. If that is plugged in remove it and try with out it. It lowers the voltage to the fan to slow it down.
PostPosted: Wed Jul 16, 2014 9:48 am
are you talking about the extra wire that came with the cooler to make the cpu run quieter. I opted to not to use it. I just normal setup. I've noticed the extra wire had a resistor on the yellow wire.
PostPosted: Wed Jul 16, 2014 2:47 pm
Reset bios. And it's running around 800 to 1400 rpm. But when I go to windows and run prime95 it started to do the same thing. The fan went down to 300 rpm and my temps went up to 97 degress after a few minutes running prime. Going to disable qfan and see if that helps.
PostPosted: Wed Jul 16, 2014 5:46 pm
Well just rma the fan. Just hoping it was a bad cooler and not something else.
PostPosted: Fri Jul 18, 2014 4:48 pm
Hope that is the case, sounds like your BIOS is doing the opposite of what it is supposed to be doing, instead of ramping up the CPU fan, its actually slowing it down. Was this a new build with this cooler, or did you install this cooler as an upgrade?
PostPosted: Fri Jul 18, 2014 7:12 pm
Not a new build. Just replace my old cooler.
PostPosted: Fri Jul 18, 2014 7:28 pm
When you put on the original heatsink what happened? Were you getting the same issues?
PostPosted: Fri Jul 18, 2014 8:05 pm
I haven't put back my hyper 212+ back in. I see no reason to. I just got confirmation that I got a replacement on the zalman. If it does the same thing. I assume it's the BIOS then. The hyper was running pretty high too but I don't think it dipped under 600 rpm b/c i never got a cpu error b/c fan was running below 600rpm.
PostPosted: Wed Jul 23, 2014 8:21 pm
Well guess what, it was the fan. All is good.
