It is currently Sun Apr 19, 2015 10:13 am
 Post subject: My HDD stops working inside the case
PostPosted: Sun Jun 22, 2014 3:33 am
As the title implies my HDD works inside the tower for a little while and then I have to pull it out and then works fine, what does this mean I need a new tower? bad cooling? just in case you are wondering the HDD its new.
 Post subject: Re: My HDD stops working inside the case
PostPosted: Sun Jun 22, 2014 6:44 am
It likely means if you care about what is on the drive you should immediately make a drive image backup as quickly as possible.
You can then download the HDD maker's free diagnostic app from their support page and test the drive. If it does not report temperature you can install HWMonitor which will usually supply min/max/current temp range for drive. I am not sure what removing the drive from the case for a while has to do with your issue.
Likely the drive is bad. But it could be the SATA data or power cable, SATA controller. Very unlikely case cooling especially in a tower. Also possible if using screws to mount hard drive they are too long and pressing into housing...they would then expand as the system and area heats up pressing further against the housing and when you remove you relieve pressure and allow a new round of failure (uncommon).
