It is currently Mon May 04, 2015 12:07 am
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
PostPosted: Wed Aug 25, 2004 7:22 pm
Sailorman
Sailorman
Juan Mendez wrote:
ZoneAlarm doesn't work on SP2. MS admits its fault along with the failure to make SP2 compatible with MS own softwares.
Yes it does. You are incorrect. You just have to use the latest version or update like a few other programs.
PostPosted: Thu Aug 26, 2004 7:44 pm
Kdiddy, you may not have to re-install.
Google "HijackThis" and download the program (also called HijackThis).
Run the program in safe mode and then remove any blatantly suspicious entries. Ususally, it will be a BHO or something, and will probably point to a .dll file in your C:\Windows or C:\WINNT directory. Make a backup of that file (just in case) and delete it. your problem should be gone when you reboot.
And yes you should definetly have a firewall installed at all times when you're on teh intarweb.
PostPosted: Sun Aug 29, 2004 9:38 pm
Team Member*
Team Member*
Here is somthing else i found from the Microsoft website:
Click Start, and then click Control Panel (or point to Settings, and then click Control Panel).
Double-click Administrative Tools.
Double-click Services.
Double-click Messenger.
In the Startup type list, click Disabled.
Click Stop, and then click OK.
