It is currently Sat Apr 25, 2015 7:19 am
 Post subject: Need an adapter for D-Sub 3 row to 2 row.
PostPosted: Sat May 10, 2014 5:02 pm
I just recently purchased an old RGB monitor. One of it's inputs is a 15 pin D-Sub that is 2 rows, but the cable I'm using is a 15 pin that is 3 rows (which is how I've always seen these cables). Is there an adapter I can get that will switch this over? I tried doing search but can't seem to find anything (I'm probably just not using the right terminology).
 Post subject: Re: Need an adapter for D-Sub 3 row to 2 row.
PostPosted: Sat May 10, 2014 5:18 pm
There's DA-15 to VGA converter, but both ends are male. My ass-pull guess is that the cable coming out of the monitor is male, so you'll also need a DA-15 gender changer for it to work. While they call it a DB-15, the actual connector is DA-15... according to Wikipedia anyway.
Gotta love sex-changing your cables and connectors ;)
PostPosted: Sat May 10, 2014 5:28 pm
Actually the connection at the monitor is female, so that adapter is perfect! Thanks for the help.
PostPosted: Sat May 10, 2014 5:49 pm
Actually I should make note of something, the converter is specifically for a Mac RGB monitor to VGA. I'll see if I can dig up something more 1-to-1.
But if you know for certain the monitor follows this pinout ( second post at http://pinouts.ru/forum/index.php?topic=4982.0 ), then you should be good.
EDIT: My searches are turning up either nothing or for the Mac adapter. I guess you'll have to take a chance.
PostPosted: Sat May 10, 2014 6:14 pm
Hrmm...not sure if that'll work then. According to the manual here is the pin layout:
1 - Red
2 - Green
3 - Blue
4 - H/COMP-SYNC
5 - V-SYNC
6 - *RESERVE* N.C.
7 - *RESERVE* N.C.
8 - *RESERVE* N.C.
9 - GND (RED)
10 - GND (GREEN)
11 - GND (BLUE)
12 - H/COMP-SYNC TTL
13 - V-SYNC TTL
14 - *RESERVE* N.C.
15 - *RESERVE* N.C.
PostPosted: Sat May 10, 2014 7:39 pm
Oh dear, this is a weird connector. Yeah, the Mac one won't work, and you're going to have to jerry rig something.
PostPosted: Sat May 10, 2014 8:11 pm
I'm wondering if it's possible to buy the end I need for the monitor, cut off the end of the VGA cable and rewire it to the new end. The only thing that confuses me, is looking at the pin layout of a regular VGA cable, there are a lot of different pins that don't do the same thing as the pins on my monitor.
PostPosted: Sat May 10, 2014 11:36 pm
The bare minimum I believe you need for VGA is just the red, blue, green signals (and their grounds) and the H/V sync lines. The other ones are just for ID. So going by what you have, 1-5 and 9-11 are the signals you need to use.
PostPosted: Mon May 12, 2014 9:57 am
Location: Rest in Peace... Stratplan & Whitecree & Thomasvjones
You said that one of the input connectors was the d-sub connector with only 9 pins.
Can you tell us what the other input connectors are?
PostPosted: Mon May 12, 2014 1:00 pm
Not quite sure what you mean, I didn't mention anything about 9 pins. Can you clarify?
PostPosted: Mon May 12, 2014 2:10 pm
Do you have the model of the monitor or equipment? I think there's more you need to wire up than I thought.
Also I think the person misread something or whatever.
PostPosted: Mon May 12, 2014 3:05 pm
It's a Mitsubishi MegaView Pro 37 (XC-3730C). I'm wanting to hook up my Wii to it with component cables, but since it doesn't have input for those cables, I'm using a Component to VGA converter. I have a scanned copy of the manual if you're interested. There is also an RGB hookup through BNC cables, but I'm planning on using that one with a SCART switch for my older retro consoles.
PostPosted: Mon May 12, 2014 4:23 pm
I found a product sheet for the monitor. I'd go with the BNC to VGA for the highest probability this will work. Though the sheet said it supports the Macintosh II and Quadra display connections, so the one I listed earlier may work.
PostPosted: Tue May 13, 2014 6:07 pm
Well I need the BNC inputs for my other, older consoles, so I can't use that one, unless I want to keep switching the cables out, which I'm trying to keep from doing. Also, if I were to use BNC, then I wouldn't need to even worry about VGA, as I would just get a component to BNC converter box and be done with it (BTW, those boxes are way too expensive, which is why I went the VGA route). The previous owner of this monitor gave me a link to this forum: http://nfggames.com/forum2/index.php?topic=55.0 which seems to confirm that the adapter will not work, and it looks like I'll just have to rewire the end of a VGA cable. Fortunately I know a guy who is pretty good doing that kind of stuff, so it should hopefully work out.
