It is currently Mon May 04, 2015 11:23 pm
 Post subject: Toshiba 3tb hdd os see's only 1/4 of drive
PostPosted: Tue Apr 22, 2014 7:24 am
I format new hdd's on a external dock, this new hdd only see's 1/4 of the 3tb, i have formatted 3tb hdd's before and had no prob's.
i thought i would post here before i send it back as defective.
Toshiba DT01ACA300
win 8.0 os
 Post subject: Re: Toshiba 3tb hdd os see's only 1/4 of drive
PostPosted: Tue Apr 22, 2014 8:28 am
If you go to Control Panel -> Administrative Tools -> Computer Management -> Storage -> Disk Management, is it possible to get a screen shot of just that drive? You can blur out whatever else but I just want to see what it says about that drive.
PostPosted: Fri Apr 25, 2014 3:36 am
it showed 756gb (not exact num but close, i am not home) of the 3tb its rated for.
usually it show 2.7tb, then i just format the drive. i format on an external dock.
addendum, i tryed on another ext dock and problem solved.
PostPosted: Fri Apr 25, 2014 3:41 am
thank you for your help.
It seams my thermatec ext dock didnt see the 3tb hdd, when i tried another it worked fine.
PostPosted: Fri Apr 25, 2014 7:07 am
Oh, d'oh.
Yeah, some older docks have trouble seeing anything beyond 2TB.
