It is currently Sun Mar 29, 2015 12:56 pm
 Post subject: Screen flicker when using video apps
PostPosted: Sat Mar 15, 2014 5:13 am
Hi guys
I'm running MaxPC's Ultimate HTPC build (http://www.maximumpc.com/article/featur ... c?page=0,0) which i've upgraded to Windows 8.1 and a 120GB Corsair Force GT as the OS drive. I have no complaints as it handles my videos and games well, except for one issue. When running a video app, most prevalently Hulu, but also Netflix, Video, and even watching a YouTube clip in desktop mode, there can be "flicker" either once it starts or ends. What I mean by that is the video and sound will cut out, not necessarily together but enough to disrupt viewing.
I'm updated to the latest drivers and such via Windows Update and Driver booster, but and can't for the life of me figure this issue out. Anyone else ever seen this or know how to fix it?
 Post subject: Re: Screen flicker when using video apps
PostPosted: Thu Mar 20, 2014 4:47 pm
OK I recently put in a EVGA GeForce GTX 770 DUAL SuperClocked 2GB, Intel Core i5-4570, CORSAIR Vengeance LP 16GB (2 x 8GB), ASUS Q87M-E LGA 1150, and CORSAIR CX series CX600 600W in my machine, reinstalled Windows 8.1, and I'm still having the cut in and out issue. Not sure what the problem could be, if I could get some help on this it'd be really nice cause it's starting to get annoying.
PostPosted: Thu Mar 20, 2014 5:51 pm
Team Member Top 250
Team Member Top 250
What is it hooked up to for display and sound? I could see this being a cable or connection, something like that, not the PC at all. What browser do you use? Does this only happen watching online videos? If it only happens with online video it could be a browser, Flash, or bandwidth issue.
PostPosted: Thu Mar 20, 2014 5:56 pm
I use Chrome, although this seems to happen more often with the Metro apps (Hulu, Netflix, Video, etc). I use all HDMI cables from the GPU, to the Soundcard, to a Pioneer A/V receiver (5.1), and up to a 42" TV.
EDIT: That's not to say that it doesn't occur on the desktop, as it has occurred when watching a Youtube clip or occasionally when starting a steam game, however it seems to be most often triggered by some sort of "change" in the video feed. I've had instances when it cut out throughout at an unbearable level, but they are anomalies compared to normal behavior
PostPosted: Thu Mar 20, 2014 6:09 pm
Team Member Top 250
Team Member Top 250
So it happens playing local video as well? (I'm guessing that's what the Video app is for, I don't use Windows 8). Have you installed the latest drivers for your GPU from NVIDIA?
PostPosted: Thu Mar 20, 2014 6:10 pm
Yes, "Video" is Window's default video app which ties into Xbox Marketplace purchases. This also briefly occurred when I tested blu ray playback on WMC
PostPosted: Thu Mar 20, 2014 6:19 pm
Team Member Top 250
Team Member Top 250
Blu-ray in WMC? What about the graphics drivers?
PostPosted: Thu Mar 20, 2014 6:21 pm
Nvidia drivers were just updated to most recent versions today
As for WMC Bluray, I have Cyberlink installed, which allows me to run the movie through WMC somehow
PostPosted: Thu Mar 20, 2014 6:29 pm
Team Member Top 250
Team Member Top 250
Soundcard drivers? Have you tried simplifying or changing any of your outputs? Like using different ports, or using just a monitor and bypassing the soundcard or using headphones instead of the receiver, that kind of thing, to eliminate problem candidates.
PostPosted: Thu Mar 20, 2014 6:47 pm
Just did some things of that nature. Previously my setup ran from GPU>Soundcard>Receiver>TV. I cut the receiver out then the soundcard and got the desired results (no cut out). Granted a brief test, but even brief tests were not promising.
So on the one hand, I'm happy it got solved. On the other hand, can't say I'm happy that the sound card beat me. Yes it was a good part back in 2010 and maybe not suited for my machine now (and the lack of company website likely means no further updates), but still, I buy these things to work.
Thanks for your help btw, if you can think of any potential fixes please don't hesitate, otherwise I'll probably dig out the card at some point.
PostPosted: Thu Mar 20, 2014 6:51 pm
Team Member Top 250
Team Member Top 250
Offhand I can't think of anything, maybe those more knowledgeable will have suggestions. But, really, using onboard audio isn't the end of the world. Although I agree with you about wanting things to work, seeing as you bought it and all. I'm glad you were able to get some resolution, a diagnosis if nothing else.
Users browsing this forum: FascistNation and 7 guests
