It is currently Tue May 05, 2015 8:34 pm
 Post subject: screws on the fan
PostPosted: Fri Mar 14, 2014 5:46 pm
My pc case fan is using the plastic threaded screws that cut into the fan when it is screwed in. and now i want to take out the screw to put in a non magnetic dust filter . so if i unscrew it will i be able to reuse that screw or do i have to get a new one?
 Post subject: Re: screws on the fan
PostPosted: Fri Mar 14, 2014 7:27 pm
Reuse it, because it's what drilled those threadings in the first place.
