It is currently Sat Apr 25, 2015 12:24 pm
 Post subject: video card not showing up
PostPosted: Tue Mar 11, 2014 7:34 am
Ok built new com and can not get the new video card to show up on vista 32bit. I have updated motherboard bio, and video card drivers. My question is if I switch out card to my older one and it works does that mean my new card is bad? Or if my old card does not work either, does that mean motherboard is bad? Right now I plugged both six pin power cable to card with same cable, will using different cable for each plug make a different? I know motherboard only has 2 2.0 pci exp slot and card is 3.0 will that make a different? Video card does work at least partially because brings pic up on monitor.
ASUS M5A97 R2.0
SAPPHIRE Vapor-X 100364VXBF4L Radeon R9 270X
 Post subject: Re: video card not showing up
PostPosted: Tue Mar 11, 2014 8:05 am
Yeah It is my video card, old one works in the new system. But, if anybody has any idea's for me to try that be cool.
PostPosted: Tue Mar 11, 2014 8:35 am
Try updating BIOS. I've had BIOS compatibility snags before with GPUs of differing generations and updating/rolling back (yes, I've had to do that) often worked.
Users browsing this forum: No registered users and 13 guests
