It is currently Thu Mar 05, 2015 4:12 pm
 Post subject: 3TB's Partitioned As NTFS With MBR Out There?
PostPosted: Sun Dec 22, 2013 4:57 am
Guys,
Windows 7 Pro SP1 64-Bit with an ASRock P67 PRO3 (B3) MoBo
that has a UEFI BIOS, i5-2500K and Corsair Vengeance 16 Gigs.
My C, D and E partitions are on a 120 GB NTFS SSD with a MBR.
My present STORAGE HDD is a 2TB Toshiba with a MBR.
I recently purchased a Toshiba PH3300U-1I72 3TB to replace the 2TB.
I always Ghost with DOS Bootable CDs I make with custom
Autoexec.bat files I write, never Windows.
I found out from Symantec that Ghost has issues with GPT.
I found a way to make my 3TB FULLY accessible and set as MBR.
It's Acronis True Image, aka Seagates DiskWizard aka WD's version
of DiskWizard. It puts an "Extended Capacity Manager" in the boot
sector so you get one 2.1TB and one 700+GB partition, BOTH MBR.
See: Seagate DiscWizard CloneDisc for drives larger than 3TB_Part-2
https://www.youtube.com/watch?v=TCLGfj1LSmI
The reason that I'm posting this is to get feedback from anyone who
has used these programs to see if the 3TBers work as any other HDD
would or are there any quirks that have come up since partitioning
your 3TB?
Please post to me.
Thanks in advance for your help.
Big Al
 Post subject: Re: 3TB's Partitioned As NTFS With MBR Out There?
PostPosted: Sun Dec 22, 2013 9:51 am
This is an old trick (literally going back to the DOS days when disk partition limit problems had previously been hit). It works fine as long as you don't mind your >2Tb drives being carved in two to four partitions. I suppose it depends upon how it does it.
I'm just not sure with your setup why a GPT formatted drive is not recognized by Win7Pro on a P67 MB with up to date BIOS revision, chipset and SATA/RAID drivers.
Unless you cannot have a mix of MBR and GPT drives on the same PC or controller???? I see that in order to do this the boot drive needs be GPT.
Users browsing this forum: No registered users and 13 guests
