It is currently Sun Apr 26, 2015 4:15 am
 Post subject: Truecrypt Windows 8
PostPosted: Mon Dec 09, 2013 7:43 am
Hello all, I wanted to make a truecrypt drive but I cant install it on windows 8x64. Im curious to know how those that had trucrypt partitions are getting around the windows 8 problem after they migrate to 8. I searched on google and many people cant install trucrypt on win8.
Thanks for any info.
 Post subject: Re: Truecrypt Windows 8
PostPosted: Mon Dec 09, 2013 9:26 am
Looking into this, TrueCrypt isn't fully supported on Windows 8, but otherwise I've found you can install it. So the question is, are you running into any errors or is the installer just telling you it failed?
PostPosted: Mon Dec 09, 2013 11:18 am
When I tried to install it i get and error code 0x0000 or similar then the computer hangs spinning circle and I have to restart. I tried running as administrator and I get the same error.
PostPosted: Mon Dec 09, 2013 1:17 pm
The only thing I can think of is that TrueCrypt has no support for GPT partitions yet, and Windows 8 requires a GPT partitioned drive.
PostPosted: Tue Dec 10, 2013 11:13 am
yup. I had an 64-bit alternative (besides bitlocker) commercial encryption app that worked on GPT partitions and Win8, but can't find the link as my laptop is down until a new AC adapter gets here tomorrow. Just remember the app was from a Scandinavian county.
edit: Found it online.
