It is currently Wed Jan 28, 2015 11:51 am
 Post subject: Colour Profile Returns to Generic PnP monitor every startup
PostPosted: Sun Dec 08, 2013 3:27 am
I have a dual monitor setup between a Dell Ultrasharp U2410 and a Wacom Cintiq. My cintiq has its colour set to a calibrated SRGB profile, and I used the same profile on my Dell. However, every single time I start up the computer the Dell returns to "Generic PnP Monitor" despite deleting it from the options. When I try to completely remove it from the computer, it won't let me because it's "In use".
In short, I want to get rid of the generic PnP profile and have it stay with the calibrated profile without having to constantly reset it every time the computer sleeps or starts up. How do I do this?
 Post subject: Re: Colour Profile Returns to Generic PnP monitor every star
PostPosted: Sun Dec 08, 2013 9:43 am
Try http://en.community.dell.com/support-fo ... 62196.aspx
Also if you're using a VGA cable, swap it out for DVI or HDMI<->DVI if possible. I know VGA can carry ID info, but you can run VGA with a minimum of 6 pins. If you got a really cheap cable, it maybe excluding certain signals.
PostPosted: Sun Dec 08, 2013 8:12 pm
I'm using a displayport cable.
