It is currently Sat Apr 25, 2015 5:26 am
 Post subject: Handbrake Video Encode Fails
PostPosted: Mon Nov 11, 2013 9:45 am
I tried using Handbrake to encode a new DVD I recently purchased and it keeps stopping 15-30% of the way through the process. I am using AnyDVD HD 7.3.6.0 and Handbrake 0.9.9.5470 (32bit). I rip the DVD using AnyDVD to a HD and transcode to another HD on my system. I tried transcoding a DVD rip that was successfully done before and it also failed, so I don't believe it is a problem with the new DVD file.
I also downloaded Handbrake 0.9.9.5530 (64bit) and had the same problem.
I recently upgraded from Windows 8 (64) to Windows 8.1 (64), installed a TPM on my motherboard and activated Bitlocker on my C drive. I don't think I transcoded any videos between updating Windows and installing the TPM/Bitlocker.
CPU temps idle at 30C, spike to 70C when handbrake starts, level off at 56C during transcode.
System:
MB: ASUS Maximus V Formula
CPU: Intel i7 3770K
RAM: 16MB G-Skill DDR3 (dual channel)
GPU: ASUS DirectCu II Top NIVIDIA GeForce GTX 680
Any suggestions on what to try next? An alternative transcoding software?
See Handbrake Encode Log below.
Thanks,
David
Encode Log:
HandBrake 0.9.9.5470 - 32bit Version
OS: Microsoft Windows NT 6.2.9200.0
CPU: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
Ram: 16328 MB, Screen: 2560x1600
Temp Dir: C:\Users\David\AppData\Local\Temp\
Install Dir: C:\Program Files (x86)\Handbrake
Data Dir: C:\Users\David\AppData\Roaming\HandBrake\HandBrake\0.9.9.5470
CLI Query: -i "V:\Game of Thrones\GAME_OF_THRONES_S2_DISC1 Side 1" -t 1 --angle 1 -c 1-9 -o "K:\Game Of Thrones S2 Disc1 Side 1-1.mp4" -f mp4 -w 720 --loose-anamorphic --modulus 2 -e x264 -q 22 -r 30 --pfr -a 1 -E faac -6 dpl2 -R Auto -B 128 -D 0 --gain 0 --audio-fallback ffac3 --x264-profile=main --h264-level="3.1" --verbose=1
User Query: False
[09:46:15] hb_init: starting libhb thread
HandBrake 0.9.9 (2013051800) - MinGW i686 - http://handbrake.fr
8 CPUs detected
Opening V:\Game of Thrones\GAME_OF_THRONES_S2_DISC1 Side 1...
[09:46:15] hb_scan: path=V:\Game of Thrones\GAME_OF_THRONES_S2_DISC1 Side 1, title_index=1
libbluray/bdnav/index_parse.c:162: indx_parse(): error opening V:\Game of Thrones\GAME_OF_THRONES_S2_DISC1 Side 1/BDMV/index.bdmv
libbluray/bdnav/index_parse.c:162: indx_parse(): error opening V:\Game of Thrones\GAME_OF_THRONES_S2_DISC1 Side 1/BDMV/BACKUP/index.bdmv
libbluray/bluray.c:1725: nav_get_title_list(V:\Game of Thrones\GAME_OF_THRONES_S2_DISC1 Side 1) failed (01CD5370)
[09:46:15] bd: not a bd - trying as a stream/file instead
libdvdnav: Using dvdnav version 4.1.3
libdvdread: Encrypted DVD support unavailable.
libdvdread: Device (null) inaccessible, CSS authentication not available.
NAME OPEN FAILED
libdvdnav: Unable to find home directorylibdvdnav: DVD disk reports itself with Region mask 0x00000000. Regions: 1 2 3 4 5 6 7 8
[09:46:15] scan: DVD has 12 title(s)
[09:46:15] scan: scanning title 1
[09:46:15] scan: opening IFO for VTS 1
[09:46:15] scan: duration is 00:52:38 (3158053 ms)
[09:46:15] pgc_id: 1, pgn: 1: pgc: 01CDA928
[09:46:15] scan: vts=1, ttn=1, cells=0->8, blocks=1480996->3, 1458938 blocks
[09:46:15] scan: checking audio 1
[09:46:15] scan: id=0x80bd, lang=English (AC3), 3cc=eng ext=0
[09:46:15] scan: checking audio 2
[09:46:15] scan: id=0x81bd, lang=Francais (AC3), 3cc=fra ext=0
[09:46:15] scan: checking audio 3
[09:46:15] scan: id=0x82bd, lang=Espanol (AC3), 3cc=spa ext=0
[09:46:15] scan: checking subtitle 1
[09:46:15] scan: id=0x20bd, lang=English, 3cc=eng ext=0
[09:46:15] scan: checking subtitle 2
[09:46:15] scan: id=0x21bd, lang=Francais, 3cc=fra ext=0
[09:46:15] scan: checking subtitle 3
[09:46:15] scan: id=0x22bd, lang=Espanol, 3cc=spa ext=0
[09:46:15] scan: checking subtitle 4
[09:46:15] scan: id=0x23bd, lang=Portugues, 3cc=por ext=0
[09:46:15] scan: checking subtitle 5
[09:46:15] scan: id=0x24bd, lang=Chinese, 3cc=zho ext=0
[09:46:15] scan: checking subtitle 6
[09:46:15] scan: id=0x25bd, lang=Korean, 3cc=kor ext=0
[09:46:15] scan: checking subtitle 7
[09:46:15] scan: id=0x26bd, lang=Thai, 3cc=tha ext=0
[09:46:15] scan: title 1 has 9 chapters
[09:46:15] scan: chap 1 c=0->0, b=1480996->1536423 (55428), 114180 ms
[09:46:15] scan: chap 2 c=1->1, b=1536424->1752190 (215767), 501408 ms
[09:46:15] scan: chap 3 c=2->2, b=1752191->1965337 (213147), 478547 ms
[09:46:15] scan: chap 4 c=3->3, b=1965338->2143712 (178375), 371238 ms
[09:46:15] scan: chap 5 c=4->4, b=2143713->2363749 (220037), 432298 ms
[09:46:15] scan: chap 6 c=5->5, b=2363750->2635344 (271595), 563422 ms
[09:46:15] scan: chap 7 c=6->6, b=2635345->2928718 (293374), 617489 ms
[09:46:15] scan: chap 8 c=7->7, b=2928719->2939929 (11211), 79291 ms
[09:46:15] scan: chap 9 c=8->8, b=0->3 (4), 176 ms
[09:46:15] scan: aspect = 1.77778
[09:46:15] scan: decoding previews for title 1
[09:46:15] scan: title angle(s) 1
[09:46:15] scan: audio 0x80bd: AC-3, rate=48000Hz, bitrate=448000 English (AC3) (5.1 ch)
[09:46:15] scan: audio 0x81bd: AC-3, rate=48000Hz, bitrate=448000 Francais (AC3) (5.1 ch)
[09:46:15] scan: audio 0x82bd: AC-3, rate=48000Hz, bitrate=192000 Espanol (AC3) (Dolby Surround)
[09:46:15] scan: 10 previews, 720x480, 23.976 fps, autocrop = 0/0/0/0, aspect 16:9, PAR 32:27
[09:46:15] libhb: scan thread found 1 valid title(s)
+ title 1:
+ vts 1, ttn 1, cells 0->8 (1458938 blocks)
+ duration: 00:52:38
+ size: 720x480, pixel aspect: 32/27, display aspect: 1.78, 23.976 fps
+ autocrop: 0/0/0/0
+ chapters:
+ 1: cells 0->0, 55428 blocks, duration 00:01:54
+ 2: cells 1->1, 215767 blocks, duration 00:08:21
+ 3: cells 2->2, 213147 blocks, duration 00:07:59
+ 4: cells 3->3, 178375 blocks, duration 00:06:11
+ 5: cells 4->4, 220037 blocks, duration 00:07:12
+ 6: cells 5->5, 271595 blocks, duration 00:09:23
+ 7: cells 6->6, 293374 blocks, duration 00:10:17
+ 8: cells 7->7, 11211 blocks, duration 00:01:19
+ 9: cells 8->8, 4 blocks, duration 00:00:00
+ audio tracks:
+ 1, English (AC3) (5.1 ch) (iso639-2: eng), 48000Hz, 448000bps
+ 2, Francais (AC3) (5.1 ch) (iso639-2: fra), 48000Hz, 448000bps
+ 3, Espanol (AC3) (Dolby Surround) (iso639-2: spa), 48000Hz, 192000bps
+ subtitle tracks:
+ 1, English (iso639-2: eng) (Bitmap)(VOBSUB)
+ 2, Francais (iso639-2: fra) (Bitmap)(VOBSUB)
+ 3, Espanol (iso639-2: spa) (Bitmap)(VOBSUB)
+ 4, Portugues (iso639-2: por) (Bitmap)(VOBSUB)
+ 5, Chinese (iso639-2: zho) (Bitmap)(VOBSUB)
+ 6, Korean (iso639-2: kor) (Bitmap)(VOBSUB)
+ 7, Thai (iso639-2: tha) (Bitmap)(VOBSUB)
+ 8, Closed Captions (iso639-2: eng) (Text)(CC)
[09:46:15] 1 job(s) to process
[09:46:15] starting job
[09:46:15] sync: expecting 75717 video frames
[09:46:15] job configuration:
[09:46:15] * source
[09:46:15] + V:\Game of Thrones\GAME_OF_THRONES_S2_DISC1 Side 1
[09:46:15] + title 1, chapter(s) 1 to 9
[09:46:15] * destination
[09:46:15] + K:\Game Of Thrones S2 Disc1 Side 1-1.mp4
[09:46:15] + container: MPEG-4 (.mp4 and .m4v)
[09:46:15] * video track
[09:46:15] + decoder: mpeg2
[09:46:15] + bitrate 9800 kbps
[09:46:15] + frame rate: 23.976 fps -> peak rate limited to 30.000 fps
[09:46:15] + filters
[09:46:15] + Framerate Shaper (2:27000000:900000)
[09:46:15] + frame rate: 30.000 fps -> peak rate limited to 30.000 fps
[09:46:15] + Crop and Scale (720:480:0:0:0:0)
[09:46:15] + source: 720 * 480, crop (0/0/0/0): 720 * 480, scale: 720 * 480
[09:46:15] + loose anamorphic
[09:46:15] + storage dimensions: 720 * 480, mod 2
[09:46:15] + pixel aspect ratio: 32 / 27
[09:46:15] + display dimensions: 853 * 480
[09:46:15] + encoder: H.264 (x264)
[09:46:15] + h264 profile: main
[09:46:15] + h264 level: 3.1
[09:46:15] + quality: 22.00 (RF)
[09:46:15] * audio track 1
[09:46:15] + decoder: English (AC3) (5.1 ch) (track 1, id 0x80bd)
[09:46:15] + bitrate: 448 kbps, samplerate: 48000 Hz
[09:46:15] + mixdown: Dolby Pro Logic II
[09:46:15] + encoder: AAC (faac)
[09:46:15] + bitrate: 128 kbps, samplerate: 48000 Hz
NAME OPEN FAILED
libdvdnav: DVD disk reports itself with Region mask 0x00000000. Regions:[09:46:15] encx264: min-keyint: 30, keyint: 300
1[09:46:15] encx264: encoding with stored aspect 32/27
2 3[09:46:15] encx264: Encoding at constant RF 22.000000
4 5 6 7 8
x264 [warning]: --psnr used with psy on: results will be invalid!
x264 [warning]: --tune psnr should be used if attempting to benchmark psnr!
x264 [info]: using SAR=32/27
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX
[09:46:15] reader: first SCR 146 id 0xe0 DTS 22254
[09:46:15] mpeg2: "Chapter 1" (1) at frame 0 time 3003
x264 [info]: profile Main, level 3.1
[09:46:15] sync: first pts is 3003
 Post subject: Re: Handbrake Video Encode Fails
PostPosted: Sun Dec 22, 2013 7:34 pm
Malware specialist
Malware specialist
This is an older thread, so not sure if you are still monitoring, but this would probably be better suited on the Handbrake forums.
Do you have AnyDVD enabled while using Handbrake? I've found that AnyDVD tends to conflict with certain software.
Another option would be to try an alternative program like MakeMKV to see if the problem persists.
