It is currently Sat Jan 31, 2015 5:47 am
 Post subject: Cable Lengths
PostPosted: Tue Nov 05, 2013 5:38 pm
MUST I only use 6' cables when hooking my pc up to my HDTV and my HD Monitor??? Can't I use an 8' HDMI cable and/or an 8' DVI-D cable?
 Post subject: Re: Cable Lengths
PostPosted: Tue Nov 05, 2013 7:55 pm
There's no reason you can't. It's just that as the cable gets longer the signal gets crappier (but that starts happening after 15 feet for cheap cables)
PostPosted: Sun Nov 10, 2013 4:15 am
Yeah, everyone knows why longer cables aren't as good as shorter cables, I just wanted to know the length at which degradation is noticeable.
PostPosted: Sun Nov 10, 2013 7:36 am
I think that would depend on the quality of the cable, a cheap one would degrade sooner than a quality cable. I have used 6' and a 10' cable on the same connection with no discernible difference in picture quality.
PostPosted: Sun Nov 10, 2013 12:37 pm
robertco300 wrote:
....I just wanted to know the length at which degradation is noticeable.
https://en.wikipedia.org/wiki/HDMI#Cables
PostPosted: Sun Dec 01, 2013 9:00 am
IF you are really worried about the quality you could always run an active cable. I think I read they are good up to like 60'
