It is currently Tue Jan 27, 2015 1:32 pm
 Post subject: Cryptolocker virus help :-/
PostPosted: Mon Oct 07, 2013 10:26 pm
My Intel t420s work laptop was got a bug!
Cryptolocker is the name. Not screwing with the machine until I here from the guru's here.
Don't want to screw anything up.
Nod32 antivirus is on the machine, but unable to update.
SuperantiSpyware is on, but not seeing anything on the scan.
Windows defender sees nothing
Any advise on how to move forward would be great!
Thank you!
 Post subject: Re: Cryptolocker virus help :-/
PostPosted: Tue Oct 08, 2013 7:17 am
Million Club - 5 Plus
The first thing I'd try is Malwarebytes. If that doesn't work, then your best bet would be to use your backup files.
Paying the "ransom" may not work as the server has been supposedly offline since mid-September.
http://mw-computers.com/wp-content/uplo ... -Alert.pdf
http://community.spiceworks.com/topic/3 ... nds-beware
PostPosted: Tue Oct 08, 2013 12:36 pm
It is easy to remove the ransomware, but your files are lost. As was mentioned, even if you go to Walmart and buy a GreenDot card and pay the ransom the server is shut down by the FBI so will no longer work. Since it uses RSA (and NSA backdoored AES) encryption with public keys not even the NSA can decrypt your files.
One hope is using ShadowExplorer (if you don't backup) to see if any shadow copies are present to recover your files or at least an older version of them.
Man, you sure aren't alone. Bleeping Computer has a complaint/report thread that is only 3 weeks old and is 37 pages as I type this. Wilder Security is accumulating an equally impressive complaint thread. I feel badly for all who have had their files encrypted with no recourse. This is really the first I have seen of a truly destructive piece of malware in years.
PostPosted: Thu Oct 10, 2013 6:57 am
Whoops. FN is quite right. If you remove the ransomware, you also remove one of the crypto keys, and that means your data is permanently lost.
