It is currently Fri Jan 30, 2015 9:33 pm
 Post subject: Overdrive and Application profiles not displaying in Win8.1
PostPosted: Sat Sep 21, 2013 9:18 pm
x64 version. I've tried installing 13.9 and the 13.10 beta of CCC. I'm using 13.5 of CAP1 and Overdrive's only release. Yes, I know I can use BIOS to overclock, and application profiles are probably overrated. I also know that I'm better off with discrete, but until my Capstone Gold gets here, I'm stuck with the APU. I installed the utilities as administrator. I've already disabled the driver signing requirement, so unless there's something else inhibiting a component installation, it's not a WHQL certification issue. It did this with Win7 x64 also.
 Post subject: Re: Overdrive and Application profiles not displaying in Win
PostPosted: Sun Sep 22, 2013 7:27 am
IF we had some hardware specs it would greatly help out!
PostPosted: Sun Sep 22, 2013 8:58 am
Million Club - 5 Plus
I tried installing the latest 13.9 chipset drivers and while I get the newer AHCI and USB drivers installed, I get an error message saying that CCC cannot be installed. I'm on Win 7 Pro 32-bit. Instead of trying to fix things, I decided to not take any chances and just reinstalled a week-old Macrium Reflect image and will leave it alone.
PostPosted: Sun Sep 22, 2013 9:04 am
I'm assuming this is AMD's stuff... because otherwise I have no fsckin clue what you're talking about.
PostPosted: Mon Sep 23, 2013 3:12 pm
Yup. CCC = Catalyst Control Center
PostPosted: Mon Sep 23, 2013 5:07 pm
Here's the dxdiag file.
http://pastebin.com/2MMWsCL9
brb installing CCC v3.0 :L
PostPosted: Mon Sep 23, 2013 8:59 pm
Also still waiting on those specs...
PostPosted: Wed Sep 25, 2013 4:37 pm
You didn't read the dxdiag link. It has every spec you could desire.
It's a Super Flower SF-461T1-S.
I've posted the information requested in this thread already. From earlier in the post, here's a copy-paste of it:
Processor: AMD A10-6800K APU with Radeon(tm) HD Graphics (4 CPUs), ~4.1GHz
Rosewill Capstone 450W Gold
The motherboard is a GA-F2A85XM-D3H.
2400MHz (the factory defaults are 11-11-11-31 1.65V in single-channel mode), 2133MHz, and 1600MHz in dual-channel mode at 11-11-11-31 at 1.5V
Mushkin Enhanced Blackline 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 2400 (PC3 19200) Desktop Memory Model 997123R
Operating System: Win8.1 x64 Pro
PostPosted: Sat Sep 28, 2013 2:30 pm
I'm thinking it might be driver signing being enabled. The fix that I use must be applied at every boot, and it was probably disabled when I ran the installer, or even if it was disabled, would have been enabled on the next boot. There's another fix that can be applied to a specific driver, but I'm thinking if this has to be done with dozens of files, it would be impractical. There has to be a way of completely disabling driver signing permanently.
PostPosted: Sat Sep 28, 2013 9:20 pm
Team Member Top 250
Team Member Top 250
http://www.howtogeek.com/167723/how-to-disable-driver-signature-verification-on-64-bit-windows-8.1-so-that-you-can-install-unsigned-drivers/
PostPosted: Mon Sep 30, 2013 3:25 pm
That is the exact tutorial I followed when installing the drivers. That's also for a one-time boot; on the next boot, driver signing will be enabled.
PostPosted: Tue Oct 01, 2013 9:12 pm
Team Member Top 250
Team Member Top 250
Huh. Well, that's stupid. Sorry.
