It is currently Fri Jan 30, 2015 4:40 am
 Post subject: Optiplex 745 VGA Issue?!?!
PostPosted: Wed Aug 28, 2013 11:01 am
Looked everywhere, asked everyone I know. And I've come up with no solution to my problem.
Problem: I receive an error msg in BIOS when booting up this Desktop (retired College PC) regarding the VGA cord being plugged into the wrong port.
The thing is, I can't find a VGA cord to fit this port: Dell website, Best Buy...nothing. Ive heard its some dell proprietary cord I have to order?? True?
PIC* (port above is how it sits now. I'm supposed to use the bottom one (data pins 'OUT')
Uploaded with ImageShack.us
Thanks for any and all help,
-G
 Post subject: Re: Optiplex 745 VGA Issue?!?!
PostPosted: Sun Sep 08, 2013 3:39 pm
Malware specialist
Malware specialist
I'm pretty sure that bottom one is a serial port and Dell's reference guides confirm this as well.
What is the exact text of the error message you receive? You also mention this is a retired college computer, has it ever worked properly?
PostPosted: Mon Sep 09, 2013 9:08 am
Location: Rest in Peace... Stratplan & Whitecree & Thomasvjones
As hackman said, your monitor Is plugged into the right port.
I'm wondering if the message you are seeing is not, in fact a BIOS message, but some sort of error message coming from the monitor itself.
Can you borrow a different monitor and see if the message changes?
PostPosted: Mon Sep 09, 2013 11:58 am
You have an ATI video card in your system with a DVI-I (dual link) port (and an TV port (S-video)?). I suspect your system is confused. I know I am.
Ain't OP's helpful?
At any rate, get a male DVI-I (dual link) to male DVI-? monitor port cable for your system or buy an adapter for that VGA cable. An adapter is perfectly acceptable as long as your monitor does not natively exceed around 1280×1024 px or 1440 x 900 px.
