It is currently Wed May 06, 2015 1:47 pm
 Post subject: WindowsXP issue
PostPosted: Thu Aug 22, 2013 5:59 am
Team Member Top 100
Team Member Top 100
On my laptop that has Win XP on it I am having an issue that I can't seem to fix.
Normally when you open a new window it shows up on top of the current window. For some reason whenever a new window opens it is behind the current window. For example when I go to uninstall a program, after clicking remove, the window that pops up so I can continue the uninstall pops up behind my list of programs.
This happens anytime I have a window open and another one needs to open, it should become the new active window but it does not it opens behind the current active window.
I have tried changing a registry entry (not sure what one right now) that was suggested but did not fix the issue.
WinXP SP3 is the OS
Thanks for any help.
E
 Post subject: Re: WindowsXP issue
PostPosted: Thu Aug 22, 2013 2:27 pm
Backup the registry and then follow this engineers instructions:
http://answers.microsoft.com/en-us/wind ... b43cc4d436
PostPosted: Sun Aug 25, 2013 9:17 am
Team Member Top 100
Team Member Top 100
That is the same registry entry I had changed before and it is a 3. But the first time I changed it it was a huge number (I think it was 8 digits long) After reading the post at the link you posted I can see why the screen would open up in the background.
With that said it is working correctly now. Although when I original changed it, it did not work properly. So either I forgot to reboot before I tested (can't belive I would do that but I dont remember if I did or not) or when I noticed the computer was on IE6.0 I ran windows update to get any updates and upgrade it to IE8 so maybe the instalation of the updates and IE8 fixed it???? Logicly I would say it was the option one. But find it hard to belive I did not reboot.
Thanks for the help.
PostPosted: Mon Aug 26, 2013 4:40 am
Good to hear it is working again! Keep those updates up to date and you should have very little trouble with you system.
