It is currently Mon Jan 26, 2015 11:05 am
 Post subject: Blue screen after monitor turns on
PostPosted: Wed Aug 21, 2013 10:10 am
I have my computer set to turn monitor off after 10mins but it's not set to go into sleep or standby. Once i move my mouse to wake the screen up I can't move the mouse and then I get a BSOD after about 15-20s. This has happened three times in the last week. Below is the error code that I get. Thanks in advance for your help!
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 1033
Additional information about the problem:
BCCode: 116
BCP1: FFFFFA800C719010
BCP2: FFFFF88007108700
BCP3: FFFFFFFFC000009A
BCP4: 0000000000000004
OS Version: 6_1_7601
Service Pack: 1_0
Product: 768_1
Files that help describe the problem:
C:\Windows\Minidump\082113-13322-01.dmp
C:\Users\Vinnie\AppData\Local\Temp\WER-15256-0.sysdata.xml
 Post subject: Re: Blue screen after monitor turns on
PostPosted: Wed Aug 21, 2013 10:21 am
Looking at the interwebs, this is related to your graphics card. Either update the drivers (or roll back to a previous version if you're up to date) or disable sleep features in BIOS.
PostPosted: Thu Aug 22, 2013 1:31 am
create system restore point for your good working conduction or else repair os.thanku
PostPosted: Thu Aug 22, 2013 2:33 am
I agreed with the above poster.
I would suggest we reset the Bios default.
If still the same problem, try install the new mobo chipset driver, must reboot, then install the video card driver.
Next time to wake up the PC, we may also try to use the KB as well.
Hope this helps.
Bill
tech manager, WPTinc. :)
