It is currently Mon Apr 27, 2015 11:07 pm
 Post subject: Trouble with Monitor
PostPosted: Sun Aug 18, 2013 12:58 pm
Hello,
I've been experiencing a new problem with my monitor that I can't figure out. When I boot up my PC, my monitor doesn't turn on. I manually turn it on, and it shows the desktop, then turns back off. This repeats each time I try to turn on the monitor until the PC warms up. After the PC is on for a minute or 2, I try again the it turns on. Thought it was the monitor going bad, so I changed it out. Same problem on two separate monitors. This is my system configuration:
Evga 780i Mobo
Evga GTS 450 GPU (x2 in SLI)
4gig Corsair (XMS2) DDR2800 memory
Corsair TX750w Power supply
Q6600 processor
Everything seems to be working ok. Any thoughts? Maybe a setting or something going bad in my MoBo or GPUs? Help pls. Thnx!
 Post subject: Re: Trouble with Monitor
PostPosted: Sun Aug 18, 2013 3:31 pm
I would first disable sli and test with only a single card, to see if one of the cards is failing. I would also try changing cables while testing the cards.
