It is currently Sun Jan 25, 2015 2:19 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
 Post subject: Re: 3monitors and xfx 7870
PostPosted: Tue Aug 13, 2013 2:30 pm
Then either you can get another active adapter or your monitor isn't like this and you just have to forget about the whole thing.
PostPosted: Tue Aug 13, 2013 11:31 pm
Okay left everything as is and only changed the 2 accell adapters that I bought with my original choice of the xfx active adapter and it works.
PostPosted: Fri Oct 18, 2013 12:26 pm
I ran into the same problem with the Displayport to HDMI converter.
If you want to run 3 monitors, one connection has to be a true Displayport signal. Whether that's a direct Displayport out from the videocard to a monitor that has a Displayport input or using an ACTIVE Displayport adapter going to the monitor's HDMI input.
As long as one connection is like the above then you can use an HDMI and DVI with it.
PostPosted: Wed Oct 23, 2013 4:30 am
Did you go into the video driver and tell it to Detect Displays under Common Display Tasks?
PostPosted: Wed Oct 23, 2013 10:16 am
Satchboy wrote:
....As long as one connection is like the above then you can use an HDMI and DVI with it.
Or Active DVI. One of the 3 ports must be DP or look like DP ("active"). I am not sure about what is needed for the 4, 5 and 6 monitor variants.
I haven't updated this in a while:
http://www.amd.com/us/products/technolo ... ideos.aspx
http://support.amd.com/en-us/recommended
http://www.amd.com/us/products/technolo ... inity.aspx
ATI Eyefinity technology works with games that support non-standard aspect ratios, which is required for panning across multiple displays. To enable more than two displays, additional panels with native DisplayPort™ connectors, and/or DisplayPort™ compliant active adapters to convert your monitor’s native input to your cards DisplayPort™ or Mini-DisplayPort™ connector(s), are required. ATI Eyefinity technology can support up to 6 displays using a single enabled ATI Radeon™ graphics card with Windows Vista or Windows 7 operating systems - the number of displays may vary by board design and you should confirm exact specifications with the applicable manufacturer before purchase. Systems using multiple ATI Radeon™ graphics cards can support a maximum of 8 displays (total across all cards in system) with a maximum 6 of those displays being used together in a display group (also known as a single large surface mode).
http://sites.amd.com/cn/Documents/48404 ... _42810.pdf
http://www.amd.com/us/Documents/IDC_Whi ... finity.pdf
http://www.amd.com/us/Documents/50279_A ... 1-2_WP.pdf
http://support.amd.com/us/kbarticles/Pa ... roups.aspx
http://www.amd.com/us/products/technolo ... et-up.aspx
http://sites.amd.com/us/business/produc ... onals.aspx
http://www.amd.com/US/PRODUCTS/TECHNOLO ... /faqs.aspx
http://support.amd.com/us/kbarticles/Pa ... yPort.aspx
http://www.amd.com/us/products/technolo ... m-monitors
http://www.maximumpc.com/article/featur ... s?page=0,0
http://www.tomshardware.co.uk/fx-8350-c ... 32616.html
PostPosted: Thu Oct 24, 2013 10:53 am
Any additional monitors will need a native Displayport connection.
For example for 6 monitors you will need at least 4 with a native Displayport connection and the other two can be anything else.
There are Displayport hubs you can get that will split a single output so you can hook up a multiple monitors.
