It is currently Wed May 06, 2015 12:31 am
Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
 Post subject: 3monitors and xfx 7870
PostPosted: Sat Aug 10, 2013 6:14 pm
Im having some troubles with connecting all 3 of my Samsung monitors
Monitor 1-hdmi
Monitor 2-hdmi to dp adapter
Monitor 3-hdmi to dp adapter/DB15pin to dvi
And I only get 2 screens on at all times and I cannot seem to get the disabled screen duplicated and it just says replace or extend with no luck. Could it be my adapter is wrong or am I doing something wrong??
http://www.homedepot.com/p/CE-TECH-Mini ... gbwpqjn-Ag
 Post subject: Re: 3monitors and xfx 7870
PostPosted: Sat Aug 10, 2013 7:54 pm
So Monitor #1 is HDMI-HDMI from Video card to Monitor?
#2 is Mini-Display Port from Video Card to HDMI on the Monitor
#3 is Mini Display Port on the video card to VGA adapter to DVI adapter to HDMI on Monitor? I would say this is probably the issue way too many adapters. Is there a reason you aren't running DVI from the video card to the DVI Port on the monitor or DVI on the video card to HDMI on the monitor?
PostPosted: Sat Aug 10, 2013 7:59 pm
On my new monitors they only have VGA and HDMI. I just bought a hdmi cable that goes into dp and still no luck. And with my 7870 only the top DVI port can convert DVI to VGA. And with the hdmi to dp cable I still have no luck with out one or the other screen going out like atm I have the #1 hdmi to hdmi and #2 hdmi dp cable monitors working but not the VGA to DVI
PostPosted: Sat Aug 10, 2013 8:08 pm
Are your adapters active adapters?
http://support.amd.com/us/eyefinity/Pages/eyefinity-dongles.aspx
PostPosted: Sat Aug 10, 2013 8:11 pm
nsvander wrote:
Well the hdmi to dp is one whole cable and the dvi to vga is the adapter that came with the video card.
PostPosted: Mon Aug 12, 2013 1:36 pm
#1 HDMI---------->Working
#2 VGA to DVI-D---------->Working
#2 VGA->DVI->DVI-D to mini DP and still --------->nothing.
#3 HDMI to DVI-D to mini DP(ACTIVE by accell mini DP to DVI-D)---------->And this screen is not even being detected
#3 VGA->DVI->DVI-D to mini DP and still---------> nothing.
What am I doing wrong, like their is no signal no nothing and I also have done the connecting only the active adapter and restarting and still nothing.
PostPosted: Mon Aug 12, 2013 5:36 pm
TTT
PostPosted: Mon Aug 12, 2013 6:46 pm
Could it be my monitors and I need a dual link active adapter? S22C350.
Also here is my comp specs
-Q6600 3.4
-PSU 550watt
-Asus maximums formula
-XFX HD7870 2GB
PostPosted: Mon Aug 12, 2013 6:53 pm
The ones that aren't working I believe you have too many adapters. And some of them don't even carry the correct signal. For instance, HDMI and DP do not have a VGA signal even though their DVI adapters support all of the pins. Picking from the lot, I'm going to infer your card as 2 DVI, 1 HDMI, and 1 DP... So if you have something that requires VGA, then convert it from one of the DVI ports. Otherwise, it's best to not convert at all.
PostPosted: Mon Aug 12, 2013 8:40 pm
I was thinking the same thing as well but only 1 of the 2 dvi ports can convert to VGA. But to me it seems that my active adapter which is from mini dp to DVI-D then to VGA and or hdmi(Which as well doesn't work) isn't functioning. I tried to update the firmware but it says that their isn't a active dp to begin with.
PostPosted: Mon Aug 12, 2013 10:30 pm
So... All your monitors are VGA only?
PostPosted: Mon Aug 12, 2013 11:08 pm
Well VGA and HDMI which makes no sense since these screens are brand new by Samsung and their LED. Could it be that I have to roll back my drivers like it says on the accell website?
PostPosted: Tue Aug 13, 2013 8:15 am
It would be better to use the HDMI port then since it's a DVI signal anyway. So:
#1: DVI -> HDMI
#2: DVI -> HDMI
#3: HDMI or DP -> DVI -> HDMI
PostPosted: Tue Aug 13, 2013 10:56 am
#1: DVI -> HDMI
#2: DVI -> HDMI
But doesn't the 3rd monitor have to be active dp and also would that even matter if my active dp isn't working even tho it doesn't function when it is the only monitor plug in when turned on?
PostPosted: Tue Aug 13, 2013 11:09 am
No, there are passive DP->DVI converters
PostPosted: Tue Aug 13, 2013 11:25 am
But to connect the 3rd monitor it has to be a active adapter??
PostPosted: Tue Aug 13, 2013 11:38 am
No.
Just don't use DP at all.
PostPosted: Tue Aug 13, 2013 12:00 pm
Connecting multiple monitors for AMD Eyefinity technology couldn’t be simpler. There are four easy rules to remember:
1.The first two monitors can connect to the graphics card with any display output on your product: HDMI, VGA, DVI or DisplayPort.
2.The third (or greater) display must be connected to the graphics card via DisplayPort.
3.If your monitor does not have a DisplayPort connection, you will need an inexpensive active DisplayPort adapter for it. DVI to DP adapters can be had for less than $30 USD.2
4.Every family of GPUs supports a different maximum number of displays.
PostPosted: Tue Aug 13, 2013 12:02 pm
Oh, forgot about that. Anyway, whatever, just find a DP->DVI adapter and plug it in a DVI->HDMI adapter. It doesn't have to be an active adapter.
Wikipedia wrote:
The DisplayPort signal is not compatible with DVI or HDMI. However, Dual-Mode DisplayPorts are designed to transmit a single-link DVI or HDMI 1.2/1.4 protocol across the interface through the use of an external passive adapter that selects the desired signal and converts the electrical signaling from LVDS to TMDS. VGA and dual-link DVI, on the other hand, require active adapters to convert the protocol and signal to the desired output and do not require dual-mode DisplayPorts. VGA adapters are powered by the DisplayPort connector, while dual-link DVI adapters may rely on an external power source (see compatibility with HDMI, DVI and VGA).[9]
PostPosted: Tue Aug 13, 2013 12:26 pm
Ive tried it with a passive adapter and no luck. I can only get 2 screens working at a time and I could switch between all three monitors but only have 2 on at the same time
