It is currently Sun Mar 29, 2015 1:33 pm
 Post subject: Need some serious help.USB Flash drive is playing some games
PostPosted: Sun Aug 04, 2013 6:45 am
Ok. so I bought a SanDisk cruzer orbit 32gb usb flash drive yesterday.
I pluged it into my computer and for the first time it was perfect.
I put in all the files I need onto the drive then have it unpluged.
plugged it back into the computer at night and the drive cant be regonized for 3 mins.
3 mins later the drive shows up and its empty. Not 0 / 32gb empty...but 0mb / 0 mb kind of empty.
so I did some researh.....went to device manager, have the orbit's driver uninstalled.
unplug then plug it back in, the flash drive immediately started to work again.....
I thought.....wooo...I fixed it.
but nope!!
The next unplug&plug did the same thing again. Which means I have to uninstall the driver everytime if I want to use it.
At first I thought it was my computer thats causing it. I have 3 other usbs laying around and none of them caused any problem.
hmm...so I thought...may be its the Orbit's problem? brought it back to the store have it exchanged for a new one.
and the same thing happens..........sigh...
I tried it on another computer the orbit was working perfectly fine......
so .... basically this is happeneing only on my computer with only curzer orbit...
I am running
CPU: i7 920,
Ram:12GB
OS: Win7 64bit
HELP!!!!
 Post subject: Re: Need some serious help.USB Flash drive is playing some g
PostPosted: Mon Aug 05, 2013 2:53 pm
try another brand?
With an old socket 1366 system I would guess maybe it doesn't know what to do with a high density flash chip. Could try updating BIOS, drivers but typically support is built into OS so is it up to date as well?
I assumed you tried more than one USB2 port?
PostPosted: Mon Aug 05, 2013 5:42 pm
When you say you are unplugging it, are you actually stopping and ejecting the drive, or just pulling it out of the slot?
::EDIT::
Do you happen to live in the USA? I ask this because according to SanDisk, that drive is not yet available here in stores
"The Cruzer Orbit USB Flash Drive is currently available for in-store purchase in select Asia Pacific and Europen countries only; United States customers may purchase the Cruzer Orbit USB Flash Drive via the SanDisk online store."
PostPosted: Tue Aug 06, 2013 8:33 am
FascistNation wrote:
try another brand?
Hi, thanks for taking your time to reply to my post.
Yes, I updated everything I could. BIOs, OS. I even have every usb driver reinstalled.
My mobo is Asus :Rampage II extreme.
Weird thing is...the PC I use in my office is running pentium 3 and the drive still works fine...
haha yes..I tried all 12 usb slots I have ...
::EDIT::
I tried both. Stopping or yanking both does the exact same thing to me.
I live in Hong Kong and I got the flash drive off a legit SanDisk reseller.
PostPosted: Tue Aug 06, 2013 9:04 am
Take it back if possible. If not, then crack it open and see if you got what you think you got.
PostPosted: Fri Aug 09, 2013 7:03 am
seems Im hopeless
