It is currently Mon Apr 20, 2015 8:16 pm
 Post subject: Headphone audio balance problems
PostPosted: Sat Aug 03, 2013 1:13 pm
I have a pair of fatality brand headphones that have a analog headphone jack. I just started using them again. The problem I'm having is audio balance . I hear the background music : guitars, drums, bass and the Vocal's audio I can barely hear. I tried using Realtek Audio Manager and I haven't had any luck. I'm using motherboard onboard audio. My 2.1 speakers sound just fine, but the headphones are giving me grief.
 Post subject: Re: Headphone audio balance problems
PostPosted: Sat Aug 03, 2013 4:23 pm
Sometimes the plug isn't fully inserted. Wiggling it around may fix that.
PostPosted: Sat Aug 03, 2013 4:48 pm
Yeah , I tired wiggling it and rotating it. Thanks though.
PostPosted: Sat Aug 03, 2013 8:31 pm
Does the headphones work fine otherwise? If it doesn't, then there's probably a fault with the return wire.
