It is currently Tue May 05, 2015 5:37 am
 Post subject: Video output Freaks out after POST
PostPosted: Thu Jul 25, 2013 10:13 am
MSI H61M-P31/W8 mobo
Celeron G1610 CPU
I can get into the BIOS and change settings but when I select to boot from DVD with a Win7 disk in, monitor freaks out, flashes, after a while monitor says out of range and system shuts down.
Tried different monitor with different cables- reset BIOS to factory- re-gooped and reseated the CPU - checked under board for shorts- tried a different PSU- different RAM. To no avail
Do you guys think I should RMA the board or the CPU?
PS: I just built 9 of these with the same parts- other 8 work just fine.
 Post subject: Re: Video output Freaks out after POST
PostPosted: Fri Jul 26, 2013 3:40 am
It says in the specs that:
Quote:
MSI Reminds You...
• VGA, DVI ports can only work with CPUs with GPUs core inside.
Does your cpu have a gpu included in its core...if not, this setup won't work and you will have to use a video card.
Board Specs:
http://www.msi.com/product/mb/H61M-P31- ... div=Detail
PostPosted: Fri Jul 26, 2013 11:08 am
If you built 8 of these with the same exact specs, I would RMA the motherboard.
PostPosted: Fri Jul 26, 2013 3:03 pm
Yeah, that's what I ended up doing since I've never had a DOA CPU before.
Thx for your opinion.
PostPosted: Fri Jul 26, 2013 3:20 pm
I would have used one of the other working systems to figure out what was the bad part.
