It is currently Fri Mar 27, 2015 8:36 am
 Post subject: Drive not seen in backup program
PostPosted: Mon Jul 22, 2013 7:55 am
Dell XPS 8500 2tb with UEFI, Secure Boot & Win8.
When I select Disk Backup Acronis True Image(ATI) shows no drive or partitions. I can see the OS partition and folders if I choose Data Backup. ATI still backs it up though to another PC on the network.
Anything I need to change to make everything visible in Disk Baclup? TIA
ATI 2013 version 16.0.6514
 Post subject: Re: Drive not seen in backup program
PostPosted: Wed Jul 24, 2013 4:57 am
Just a guess, you may have to turn on sharing on the two drives you want to backup from and too.
Right click the drive, choose properties, choose sharing and set it up. Try backing up the drive now, does it work and can you see it?
PostPosted: Wed Jul 24, 2013 10:42 am
Make sure the drive is initialized. If booting up, and using Windows 8, you may need to change the UEFI to legacy support
Completely shut down your computer.
Power on the system. As soon as the first logo screen appears, immediately press F2 to enter the BIOS.
Use the right arrow key to select Boot.
With Boot Mode highlighted, press Enter, and then use the down arrow to select Legacy BIOS.
Press Enter.
Press F10, and select Yes to save the change and exit the BIOS.
