It is currently Sun Mar 29, 2015 9:07 pm
 Post subject: Video cable problem question
PostPosted: Thu Jul 18, 2013 10:25 am
I've solved my problem but the solution makes no sense to me. Therefore, I'll ask this question to see if anyone can help me understand.
My System
Custom built PC
Win XP Home SP3 (with all updates)
28" Hanns-G monitor
Graphics board connected using a 6' DVI to HDMI cable
Problem
-For some time, there were artifacts on the pre-boot screen (i.e. prior to the Windows Logo). After booting to Windows all seemed to work well.
-Recently, after about 30 minutes using the computer, the screen would either display a series of solid colours, then go black, sometimes the computer would freeze or reboot on it's own.
Solution
- I re-seated the graphics board and ensured that connections were secure
- I installed CPU & GPU heat monitors (no problems found)
- I suspected the graphics board, so I swapped out the entire PC for an older model that was no longer in use. Surprisingly, I still had the same problem.
- Then, I replaced the DVI to HDMI cable with a standard HDMI cable and that solved the problem!
My Question
I had always assumed that the cable between the graphics board and the monitor was one way - Graphics board to monitor. (i.e. The computer will boot and run without a monitor connected). I can see how a defective video cable could cause display problems. However, I can't see how a defective video cable could possibly cause the computer to freeze or reboot.
Can anyone enlighten this poor soul?
 Post subject: Re: Video cable problem question
PostPosted: Thu Jul 18, 2013 10:35 am
The cable that you used could've been bad.
And also, there is some data being transmitted back from the monitor, but it's normally information about the monitor.
