It is currently Fri Mar 06, 2015 6:42 pm
 Post subject: Replacement for Palm dessktop
PostPosted: Tue Aug 17, 2004 9:23 am
I was wondering if anyone know a good replacement for Palm desktop?
I was looking at Act or Lotus notes
Can someone recommend something else too?
 Post subject: Re: Replacement for Palm dessktop
PostPosted: Tue Aug 17, 2004 9:38 am
I'd rather be modding!
Do you actually use a Palm PDA? Or do you just want something that functions like Palm Desktop for a Computer.
Manta
PostPosted: Tue Aug 17, 2004 9:50 am
Yes I use a palm too
PostPosted: Tue Aug 17, 2004 11:19 am
7yrs+11,000 Posts
7yrs+11,000 Posts
try www.majorgeeks.com or www.downloads.com
PostPosted: Tue Aug 17, 2004 1:26 pm
I wasn't aware yu could fully replace Palm Desktop. You are aware that Act and Note don't replace Desktop - they simply import from it. You still need Desktop on your machine. At least you did a few months ago. Has there been a new version?
Curious, Why do you want to replace it?
Manta
PostPosted: Tue Aug 17, 2004 4:30 pm
Well I want to be able to move effective coordinate things and the palmdesktop doesnt have all the feature of a full PIM.
And yes I thought you could replace the plam desktop. I knoe you can you outlook with the instead of the desktop. But I don't like outlook cuz of all the holes Ms allows in it's software.
PostPosted: Tue Aug 17, 2004 4:46 pm
Well I can't help you much - but look around. See if you can get something for free first. As long as you are not dead set on removing PDT from you system you can probably find what you want. It will look like you replaced PDT - but really its using it and importing from it (and maybe exporting)
Check the first site Gamer recommended. And hopefully someone who had played with this more will reply in the mean time :)
Manta
