It is currently Fri Feb 27, 2015 12:14 am
 Post subject: Low Memory
PostPosted: Thu May 16, 2013 1:29 am
My previous laptop windows 7 is just reformatted because it suddenly after the start up. After it is reformat I have install hundred update from windows and my HP support. However, after all the updates both windows and HP I can't use anymore my windows 7 laptop because of low RAM. How can I solve its low RAM?
 Post subject: Re: Low Memory
PostPosted: Thu May 16, 2013 2:16 am
What's the HP model and can you give a snapshot of the error and task manager in both the processes and performance tabs?
PostPosted: Sat May 18, 2013 2:37 pm
Sounds like the hard drive doesn't have enough space left for the page file system to me.
PostPosted: Wed May 22, 2013 1:12 pm
Download and install WinDirStat, I recently had an issue with my main rig loosing harddrive space and I could not figure out what was going on. Turns out I had a corrupt hiberfil.sys file, and it had swollen to over 30GB (my machine does not even use sleep). Performed a simple command in command prompt and was able to delete the file.
