It is currently Sat Jan 31, 2015 7:20 am
 Post subject: Auto Restart?
PostPosted: Wed May 15, 2013 6:43 am
Hi! I was gaming last night then after I was done, I put my PC in sleep mode, then this morning I woke up and it had restarted. Seemed odd as I had put it in sleep mode, it did say windows installed new updates, and had the "need to restart to install icon" by "shutdown" on the start menu before I put it in sleep mode. So it seems like it turned back on and restarted to install updates, is this normal?
Thanks! :)
 Post subject: Re: Auto Restart?
PostPosted: Wed May 15, 2013 6:50 am
Only thing I did different was that, I normally let my PC sit and cool off for about 10 minutes before turning it off, last night I only let it sit for about 4-5 minutes. Nothing new in ".minidump".
PostPosted: Sat May 18, 2013 2:42 pm
In task properties, do you have "wake up to run this task" set to run windows updates, if you do then it will restart on its own even in sleep mode.
PostPosted: Sun May 19, 2013 2:43 pm
I'll check that out! Thanks! :)
