It is currently Tue Mar 31, 2015 3:26 am
 Post subject: NVIDIA folder opens every time I reboot!
PostPosted: Fri Apr 19, 2013 8:02 am
I updated my driver, now the stupid NVIDIA folder opens automatically every time I reboot. Why? I shouldn't be punished with this annoyance for the rest of my life. Any suggestions will be gratefully implemented.
 Post subject: Re: NVIDIA folder opens every time I reboot!
PostPosted: Fri Apr 19, 2013 11:31 am
Have you tried deleting it?
PostPosted: Fri Apr 19, 2013 6:49 pm
No! Though that's a perfectly reasonable suggestion. I always assumed my video card needed that folder for something. Does it serve no useful purpose?
PostPosted: Fri Apr 19, 2013 7:37 pm
It's a temporary folder the driver install unpacks to when installing.
PostPosted: Fri Apr 19, 2013 11:38 pm
Ha! That's so funny. Thank you, I learned something this day.
Odd that these programs don't clean up after themselves.
I've always figured that pretty much everything a computer does, it does because it was told to do so, by some programmer who wrote the code because he thought it was a good idea. If so, can you tell me why someone thought it would be a good idea for my NVIDIA folder to open every time I reboot?
thanks,
trailmeister :)
PostPosted: Sun Apr 21, 2013 10:48 pm
Interesting problem. I'm curious as to what your OS is?
PostPosted: Mon Apr 22, 2013 1:19 am
I'm running Windows XP home edition.
PostPosted: Mon Apr 22, 2013 4:23 am
That folder should not open at all. Have you run your Anti-virus and Malwarebytes to see if a gremlin snuck in and is causing this issue?
PostPosted: Tue Apr 23, 2013 7:58 am
I was protected by AVG Free anti-virus and ZoneAlarm firewall. I don't have Malwarebytes and would like to avoid paying $25 unless you think it's absolutely necessary. But because you mentioned Malwarebytes, I uninstalled AVG and ZoneAlarm, and I replaced them with Norton 360, which my brother had an extra license for. I ran a full scan. One hour and 360,116 items later, no malware was found, save for several tracking cookies.
PostPosted: Tue Apr 23, 2013 8:07 am
Malwarebytes has a free version of their program, you just don't get automatic updates or malicious IP blocking.
PostPosted: Tue Apr 23, 2013 2:14 pm
From the Nvidia Forums:
Quote:
NVidia installer can't handle spaces in the install path which results in a registry key without quotes. When starting your OS, NVidia will start it's software and have problems finding the nwiz.exe. To solve this problem:
1. Open the Registry editor:
1.1 [Windows key] + [R]
1.2 type: regedit
1.3 [Enter]
2. Edit the key
2.1 In the registry editor find the key: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run"
2.2 Click on the folder "Run"
2.3 Double click the key: nwiz
2.4 The Value in the value editor looks like: C:\Program Files\NVIDIA Corporation\nview\nwiz.exe /installquiet
2.5 See no quotes around the path as difference.
2.6 In the value editor add quotes like this: "C:\Program Files\NVIDIA Corporation\nview\nwiz.exe" /installquiet
2.7 Close the registry editor.
2.8 Have fun
PostPosted: Tue May 14, 2013 10:56 pm
Thank you, LatiosXT -- I now have a free copy of Malwarebytes. Running it turned up no gremlins, but I am grateful to have this software for next time.
FYI -- Deleting the NVIDIA folder does solve the problem. As does altering the folder's name. Good things for me to know.
PostPosted: Tue May 14, 2013 11:09 pm
nsvander (Team Member) -- you're positively brilliant.
Sorry for the delayed response.
Needless to say, your fix worked handily.
I thought I was the only person in the world with this problem and never would have checked the NVIDIA forums to see if anyone else was experiencing the same thing. I guess NVIDIA has a bug to fix before they release their next driver. I wonder why they've taken so long to address this annoying idiosyncrasy.
Thank you.
cheers,
trailmeister :)
