It is currently Tue Mar 03, 2015 11:53 pm
 Post subject: New build fails to post.
PostPosted: Sun May 05, 2013 7:08 am
Brand new build fails to post, except for once or twice. It starts, and then it hits a certain point it shuts down and then a couple of seconds later does it again...over and over until I kill it.
I'm using the following hardware:
Asus p9x79 deluxe motherboard
Intel core i7 3930
32gb g. Skill ddr3-2400
I've verified that the ram is compatible with the m/b and have tried each of the 4 sticks of ram individually, update to the latest bios, etc. and nothing changes.
The computer did boot completely 2 times, even though I didn't change anything, but once during windows install, it shut down and again was unable to boot completely.
Update: I am now able to, more often than not, boot the computer to the windows load screen but after a few seconds the computer shuts down and then reboots. I can get into safe mode but it will not load windows 7 x64 ultimate.
I have thoroughly scoured both the m/b mfr and the memory mfr forums looking for anything similar. Nothing so far.
Again, any help or suggestion, will be greatly appreciated.
 Post subject: Re: New build fails to post.
PostPosted: Sun May 05, 2013 10:33 am
It sounds as though it could be a PSU issue. What make and model of PSU are you using in this new build?
PostPosted: Sun May 05, 2013 4:21 pm
PCM power & cooling turbo cool 1kw.
I did try another power supply just in case and it had the exact same result.
PostPosted: Sun May 05, 2013 7:17 pm
finding discussion around code 70 is a little difficult, but it appears to be a code that indicates the motherboard is trying to auto-update.
I would suggest plugging in an ethernet cable and give the motherboard a few minutes (10ish); don't touch it; let it keep re-booting (or whatever) in that time. If it is still stuck at code 70 I think it is time to contact ASUS support for other suggestions. If all this fails, RMA the board.
Hope this helps.
