It is currently Wed Jan 28, 2015 10:15 am
 Post subject: Transferring Internet/Files Using Easy Transfer Cable
PostPosted: Tue Apr 30, 2013 3:24 pm
Sorry, I should have been clearer with my question. I know I can transfer a whole user file and the user data (I can't choose file by file), I wanted to know if there is a way I can pick and choose single files and transfer them one by one, or as many as I choose. I can't use the shared folder on the PC I want the files on. It does not have internet and I do not have a router I can use at the moment. I also wanted to know if I can bridge the internet from one PC to another using this cable. Thank you for your time and help.
http://www.belkin.com/us/p/P-F5U279 (the cable i am using)
 Post subject: Re: Transferring Internet/Files Using Easy Transfer Cable
PostPosted: Tue Apr 30, 2013 7:38 pm
There should be an application that's supposed to also come with the cable to works with...
Never really used one myself, but they do work
PostPosted: Tue Apr 30, 2013 8:17 pm
Easy Transfer is a Windows utility. https://en.wikipedia.org/wiki/Windows_Easy_Transfer
