It is currently Sun Jan 25, 2015 7:04 pm
 Post subject: DI-604 + Surfboard SB5100 = lotsa blinky lights
PostPosted: Mon Aug 16, 2004 8:16 pm
I just got our cable modem and router ready to go in our new house.
Everything works, but I noticed that as soon as I plug the ethernet cable from the modem to the WAN port on the router, the WAN indicator light and the STATUS light on the modem are blinking rapidly and they never stop.
When I plug the modem directly to my PC, the status light does not blink in this manner.
Any ideas?
This happens even if no computers are plugged into the LAN ports...
PostPosted: Mon Aug 16, 2004 9:33 pm
interrupted data transfer due to the router?
*shrug*
Deal with it? :-D
PostPosted: Mon Aug 16, 2004 9:36 pm
i have the same modem and mine right now is blinking fast too. its been doing this like year already since i have the router for about a year. do i really care? no. is my internet connection fine? yes.
PostPosted: Tue Aug 17, 2004 6:51 am
My initial thoughts are...this it's some sort of DoS, but plugging a machine onto it will make everything work (or failsafe??), you're not using a crossover, or the crossover is damaged, or that router is dungus and it's time for a new one :)
PostPosted: Tue Aug 17, 2004 7:14 am
The router is brand new. So is the modem, I just got them both from newegg last monday. I am using a patch cable and not a crossover (it wouldnt work if I was using a crossover cable anyway).
I just wanted to make sure I wasnt losing any speed due to that...
