It is currently Fri Mar 06, 2015 3:48 am
 Post subject: Sound barely audible or non-existent
PostPosted: Sun Apr 14, 2013 10:05 am
sorry if this had been posted before. I thought I had submitted this topic but it did not show up in the Free Clinic forum. The problem is my sound. For internet videos (and I assume everything else) it went from normal to barely audible. That was yesterday. Today, when I fwent an internet video, it was back at normal again, but after a while the sound got scarchy and faded back and forth between normal and barely audible. I checke the wires and connections. They don't seem to bed loose. I verifiied that the cound control on the video was at maximum and that the control on the speakers was turned all the way up, but still - barely audible. I went to the control panel and updated the sound card via the internet and did a reboot. But now, there is no sound at all. Not sure what to try next.
 Post subject: Re: Sound barely audible or non-existent
PostPosted: Wed Apr 17, 2013 7:16 pm
What kind of speakers?
Battery powered? Check the batteries
AC? Check for correct output at the plug that goes to the speaker,
Can you plug them into something else to see if they work OK?
If those are OK, try a different soundcard.
