It is currently Sun May 03, 2015 4:01 am
 Post subject: Random shut down and failure to restart.
PostPosted: Thu Mar 28, 2013 4:35 pm
I've had my new PC built since Sunday and it has ran fine up until today :cry: Today it randomly shutdown in the middle of something and tried to restart but shut back down instantly. I tried to start it again and it shut down instantly again. It kept doing this until I unplugged from the wall and let it completely power down and waited. After a bit I got it fired up and running and worked fine for about 15-20 minutes and started doing it again..... I am so lost on what the issue is. :(
CPU: i5-3570k
Heatsink: Cooler Master 212 Hyper EVO
Mobo: Gigabyte GA-Z77x-UD3H
SSD: Samsung 840 Pro 256GB
Memory: G. Skills Rip Jaws x 8GB(2x4) DDR3-1600
PSU: NZXT HALE 90 750W
Case: NZXT Phantom 410
OS: Windows 8
If anyone has any suggestions they are much appreciated, thank you.
 Post subject: Re: Random shut down and failure to restart.
PostPosted: Thu Mar 28, 2013 5:22 pm
It's the power supply. You should replace it.
PostPosted: Thu Mar 28, 2013 6:49 pm
Agreed. 100%
PostPosted: Fri Mar 29, 2013 12:01 am
Yup! It's almost certainly the PSU. I would bet that the +5v rail is putting out much less than its purported +5v. Check the PC Health Status in the motherboard's BIOS and see if that is the case. If so, then you definitely need to replace the PSU.
PostPosted: Fri Mar 29, 2013 12:47 pm
Thank you all for the responses! I am new to this so I will see what I can find in the BIOS. Again thank you all!
PostPosted: Fri Mar 29, 2013 1:36 pm
The BIOS isn't fitting my screen very well but what I am able to see is
PU VCore 1.152 v
ram voltage 1.524 v
3.3v 3.363 v
12v 12.096 v
I have no idea what the 3.3v and 12v is I am assuming the Other two are CPU and Vram
Any idea what this means????
PostPosted: Fri Mar 29, 2013 2:09 pm
The voltages are fine, but either way, this is a PSU problem.
