It is currently Sat Apr 25, 2015 7:06 am
 Post subject: IRQL_NOT_LESS_OR_EQUAL Blue Screen
PostPosted: Wed Feb 27, 2013 9:48 pm
Hi! I was playing Brink on my PC on Max at 1080P no problems at all then shut I shut down and then powered it back on about 5 minutes later and got a Blue Screen saying IRQL_NOT_LESS_OR_EQUAL. Any ides what this could mean??? I would upload a photo but my iPod takes a few life times to start the camera so I didn't have a chance, it lasted about 30 seconds. A few odd things that happened before it crashed was when I tried updating my Nvidia drivers to 313.something from 310.something it says the system scan failed and when playing Red Faction Guerrilla I had two suns, one in its normal place and one at the ground that keep shinning up in my face. Please help!
 Post subject: Re: IRQL_NOT_LESS_OR_EQUAL Blue Screen
PostPosted: Wed Feb 27, 2013 10:04 pm
Its not 313.something its 314.07.
PostPosted: Wed Feb 27, 2013 10:40 pm
http://lmgtfy.com/?q=+IRQL_NOT_LESS_OR_EQUAL
PostPosted: Wed Feb 27, 2013 11:18 pm
It sounds like a hardware or driver issue. I am now thinking its my GPU driver as I remember recently it crashed a few times and the Geforce Driver System Scan won't work. I manually downloaded the driver for it and am now going to try to install it.
PostPosted: Wed Feb 27, 2013 11:21 pm
BTW is there a way to review the last Blue Screen message from windows?
PostPosted: Wed Feb 27, 2013 11:26 pm
I just attempted to reinstall it and well... it failed. I am now running at about 800x600 instead of 1920x1080...
PostPosted: Wed Feb 27, 2013 11:27 pm
Says Graphics Driver failed to install.
PostPosted: Wed Feb 27, 2013 11:29 pm
Failed the second try...
My 3GB GTX 580 has a warranty thankfully! But... I can't remember my login name to EVGA.
PostPosted: Thu Feb 28, 2013 12:14 am
Downloaded 310.90 and it failed as well...
PostPosted: Thu Feb 28, 2013 1:13 am
Restarted my PC and got a message saying unknown driver installing and this message
Assertion failed: IsGpuDeviceSupport(Index), file
..\..\CommonLib\include\GpuLib\Source\AGL_GpuDevice.ccp, line 214
and this
GPUTweakit.exe Abnormal Program Termination
GPUTweakit a overclocking program??? I have never overclocked any part of my PC. The Unknown driver turned out to be called GTX 580 and there was a prompt to restart, I restarted and and now I am at 1920x1080 and my GPU seems to be working! Running 310.70. Geforce Auto Scan still fails... any idea why?
PostPosted: Thu Feb 28, 2013 1:39 am
Tried Morrowind to just give it a light load and it ran fine, I then tried Metro 2033 on Maximum Settings and it ran fine. So card runs fine.
PostPosted: Sun Mar 10, 2013 6:29 am
In my experience, the error you refer to is caused by faulty RAM. I would suggest running Memtest to check for bad RAM. 1 stick at a time, 1 slot at a time. Every computer I've ever worked on with that error was remedied by replacing the RAM. Hope this helps!
PostPosted: Sun Mar 10, 2013 6:37 pm
I tried Memtest, all my RAM is fine. I tried downloading the latest Graphics Drivers using Internet Explorer and it scanned and went, so apparently manually searching won't work, needs to be auto. It seems for some reason it doesn't scan it on FX but does on IE. Everything been great since! Thanks for the suggestion!
PostPosted: Fri Mar 29, 2013 5:45 pm
It crashed again... Right on start up, didn't even reach the BIO's screen...
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1033
Additional information about the problem:
BCCode: a
BCP1: 0000000000000040
BCP2: 0000000000000002
BCP3: 0000000000000001
BCP4: FFFFF800032DA1C8
OS Version: 6_1_7601
Service Pack: 1_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\032913-19406-01.dmp
C:\Users\(name)\AppData\Local\Temp\WER-28033-0.sysdata.xml
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid= ... cid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
PostPosted: Fri Mar 29, 2013 7:02 pm
I am also getting occasional sounds that sound like a sick frog, know what I mean? Kind of that sound you get in games if you try to select an unavailable option or try to pick something up but can't. I can't think of exactly how to describe it...
PostPosted: Sat Mar 30, 2013 2:40 pm
I'[d really appreciate a response! I would just Google it but I am not sure what to Google!
PostPosted: Sun Mar 31, 2013 7:38 pm
Could it be my SSD causing it? My PC worked perfect before then and never had an issue, then I reinstalled windows on a new SSD and its had the crash twice, both where a month apart. I bought the SSD 6 months ago though.
