It is currently Fri Mar 27, 2015 1:00 pm
 Post subject: Help! 127GB limit Please help me
PostPosted: Mon Aug 16, 2004 3:56 pm
i bought a western digital 160gb hard drive today, but somehow it only shows up as 127gb. can any experts out there that can help me fix this problem?
thanks
PostPosted: Mon Aug 16, 2004 4:13 pm
Here is some reading for you :)
http://wdc.custhelp.com/cgi-bin/wdc.cfg ... 1031763968
Unless you're using this drive strictly for storage, I would suggest partitioning it anyway. ie. I have a 120 gig WD drive. I have a 40gig system partition and a 80 gig storage partition.
Hope this helps. Post more specific questions if you like :)
PostPosted: Mon Aug 16, 2004 4:40 pm
im using it as a storage drive
PostPosted: Mon Aug 16, 2004 4:50 pm
What OS are you using and how'd you format the drive? because that makes a huge difference asto what you're doing.
PostPosted: Mon Aug 16, 2004 4:51 pm
OK then you can follow the option in the link I sent you or just activate the rest of your drive through administrative tools and you'll simply end up with one smaller partition.
PostPosted: Mon Aug 16, 2004 4:53 pm
im using windows xp and i right clicked on the drive and click format
PostPosted: Mon Aug 16, 2004 4:56 pm
oo_oO i went to administrative tools then fixed it.. ty so much
PostPosted: Mon Aug 16, 2004 4:58 pm
My pleasure :)
